2960-6025
2960-6025
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMARCPTR/A50OHMSOLDER
2960-6025 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING .500 12.70 REVISION HISTORY DESCRIPTION REV B DCN 41793 DATE APPROVED 10/15 DAL .705 17.91 2X .340 8.64 .590±.010 14.99±0.25 .380 9.65 .050 1.27 .600 15.24 .162 4.11 .460 11.68 4X .103±.003 2.62±0.08 .065 1.65 1/4-36 UNS-2A MATERIAL: BODIES: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CAP: STAINLESS STEEL PER ASTM A-240, ALLOY UNS S30400, TYPE 304 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 TERMINAL: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODIES & CAP: CONTACT & TERMINAL: GOLD PER ASTM B488, TYPE I, CODE C, CLASS .50, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 12.4 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 10/21/15 CHECKED: APPROVED: DAL 10/21/15 SW 04/07/97 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA JACK 4 HOLE FLANGE MOUNT, RECEPTACLE CAPTIVATED CONTACT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 2960-6025 SHEET 1 OF 1
2960-6025 价格&库存
很抱歉,暂时无法提供与“2960-6025”相匹配的价格&库存,您可以联系我们找货
  • 1+734.799801+95.11218
