4100-0001
4100-0001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNTNCPLUGR/A50OHMSOLDER
4100-0001 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 41583 DATE APPROVED 08/15 BNK 1.182±.040 30.02±1.02 .878 22.30 .500 HEX .625 15.88 3X Ø .040 .6225 15.81 ACROSS FLATS MATERIAL: OUTER CONTACT: 1.478 37.53 1.165 29.59 BERYLLIUM COPPER PER ASTM B194, ALLOY No. UNS C17200 BODIES, CENTER CONTACT, SLEEVE, COUPLING NUT, CLAMP NUT, WASHER, CLAMP & CAP: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B GASKETS & O-RING: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 LOCK RING: PHOSPHOR BRONZE PER ASTM-B 159, ALLOY 51000, TEMPER H08 WASHER: BRASS PER ASTM B36 ALLOY C26000, H02 .687 HEX. FINISH: BODY ASSEMBLY, OUTER CONTACT, SLEEVE, WASHER, COUPLING NUT, CLAMP NUT, WASHER, CLAMP & CAP: CENTER CONTACT: SILVER PER ASTM B700, TYPE 1, GRADE D, CLASS S WITH TARNISHING PROTECTION. GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: 50 OHMS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GPF 08/18/15 CHECKED: APPROVED: BNK 08/18/15 BNK 08/18/15 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: TNC CUBE R/A PLUG FOR RG9, 87, 214, 225/U CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 2:1 4100-0001 SHEET 1 OF 1
4100-0001 价格&库存
很抱歉,暂时无法提供与“4100-0001”相匹配的价格&库存,您可以联系我们找货
