CONREVSMA002-SMD
CONREVSMA002-SMD
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA002-SMD 数据手册
8 DESCRIPTION MATERIAL FINISH BODY PIN INSULATION NICKEL GOLD N/A BRASS BeCu PTFE 5 6 7 4 2 3 REVISIONS REV B D DESCRIPTION ADDEDNEW TITLE BLOCK; UPDATED FOOTPRINT DATE APPV 25-APR-12 SAH MATERIALS; UPDATED THREADS FROM 2B TO C UPDATED 2A 10-JUL-12 SAH D ADDED PIN TO PCB DIMENSION 17-OCT-12 SAH 3-MAY-16 SAH E ADDED CONTANT TO STANDOFF DIMENSION; UPDATED NOTE 3; UPDATED VARIOUS DIMENSIONS 0.598 15.20 D 0.180 4.56 0.102 2.60 4X S 0.059 1.50 C 0.425 10.80 0.291 7.40 1 0.051 1.30 0.047 1.20 0.113 2.88 0.210 5.34 0.049 1.24 1/4-36UNS-2A THREADS 0.081 2.05 S 0.276 7.00 C 0.306 7.76 0.153 3.88 0.057 1.44 0.096 2.44 A B SIDE VIEW B RECOMMENDED FOOTPRINT BOTTOM VIEW NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. A WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION 0.004 CENTER CONTACT TO MOUNTING PLANE STAND-OFF 0.000 0.10 0.00 THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. DETAIL A SCALE 12 : 1 MATERIAL: 32 FINISH: 8 7 6 5 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 4 TITLE: RP-SMA FEMALE RIGHT ANGLE SURFACE MOUNT PROJECTION: SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. B A REV DRAWN: B.MURPHY DT: 25-APR-12 CONREVSMA002-SMD E ENGR: S.HOGAN DT: 25-APR-12 SCALE: 6:1 DO NOT SCALE DRAWING SHEET 1 OF 1 3 2 1 LDCFDFB_C
CONREVSMA002-SMD 价格&库存
很抱歉,暂时无法提供与“CONREVSMA002-SMD”相匹配的价格&库存,您可以联系我们找货
