8
6
7
DESCRIPTION MATERIAL
FINISH
BODY
PIN
INSULATION
GOLD
GOLD
N/A
BRASS
BeCu
PTFE
5
4
2
3
1
REVISIONS
REV
DATE
APPV
5-MAR-12
SAH
C UPDATED MATERIALS
10-JUL-12
SAH
D ADDED DIMPLE TO PART
3-JUN-13
SAH
3-MAY-16
SAH
29-NOV-17
CLL
B
D
DESCRIPTION
ADDED NEW TITLE BLOCK; UPDATED DIMENSIONS AND
FOOTPRINT
E
ADDED CONTANT TO STANDOFF DIMENSION; UPDATED
NOTE 3
F
ADDED OUTER BARREL DIMENSION
D
4X Ø 0.018 DIMPLE(S)
EQUALLY SPACED
0.180
4.56
4X S 0.059
1.50
1/4-36UNS-2A
THREADS
0.113
2.88
A
C
0.050
1.27
0.212±0.004
5.38±0.10
0.306
7.76
0.157
4.00
0.081
2.05
C
0.153
3.88
0.157
4.00
0.039
1.00
0.310
7.87
0.409
10.40
0.096
2.44
S 0.276
7.00
0.057
1.44
RECOMMENDED FOOTPRINT
B
B
SIDE VIEW
BOTTOM VIEW
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE, USE
MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY
HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE
SOURCED MATERIALS.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
A
DETAIL A
SCALE 12 : 1
8
7
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
0.004 CENTER CONTACT TO MOUNTING PLANE STAND-OFF
0.000
0.10
0.00
MATERIAL:
32
FINISH:
6
5
INTERPRET DIMENSIONS AND
TOLERANCES PER ASME Y14.5.
4
TITLE:
A
RP-SMA FEMALE PCB MOUNT
SURFACE MOUNT
PROJECTION:
SURFACE FINISH:
ANGLES: 1
TOLERANCES: .X .1 .XX .01 .XXX .005
159 ORT LANE
MERLIN, OR 97532
SIZE DWG. NO.
REV
B
DRAWN: B.MURPHY DT: 11-MAR-13
CONREVSMA001-SMD-G
F
ENGR: S.HOGAN
DT: 3-JUN-13 SCALE: 6:1
DO NOT SCALE DRAWING
SHEET 1 OF 1
3
2
1
LDCFDFB_C
很抱歉,暂时无法提供与“CONREVSMA001-SMD”相匹配的价格&库存,您可以联系我们找货
