CONREVSMA005-R58
CONREVSMA005-R58
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA005-R58 数据手册
Description Body Pin Pin Insulator Washer Nut Spacer Shield Sleeve Retaining Nut Crimp Ring Heat Shrink Material Brass Brass PTFE Brass Brass PTFE Brass Brass Brass Polyolefin Finish Nickel Gold N/A Nickel Nickel N/A Nickel Nickel Nickel Black REVISIONS 0.126 [3.20] 0.272 [6.90] 0.276 [7.00] REV RG-58 Cable B DESCRIPTION Updated footprint and dimensions; Added new title block 1/4-36UNS-2A THREADS Ø0.177 [4.50] 0.065 [1.65] HEAT SHRINK 0.441 [11.20] Ø0.049 [1.24] PIN 0.446 [11.40] 0.020 [0.50] SAH Ø0.287 [7.30] H0.315 [8.00] 1/4-36UNS-2B THREADS 29-JUN-12 Ø0.256 [6.50] CRIMP RING Ø0.402 [10.20] APPV 0.984 [25.00] 0.500 [12.70] RECOMMENDED CABLE STRIPPING DIMENSIONS DATE Ø0.254 [6.50] 0.276 [7.00] 0.636 [16.30] Ø0.177 [4.50] SPACER 0.234 [6.00] WASHER 0.035 [0.90] 0.996 [25.30] NUT SIDE VIEW WASHER RECOMMENDED MOUNTING HOLE RETAINING NUT SPACER PIN INSULATOR CRIMP RING PIN NUT SHIELD SLEEVE MAIN BODY 4. 5. 6. 7. 8. Strip cable to recommended dimensions. Slip heat shrink and crimp ring onto stripped cable. Insert the stripped cable through the retaining nut, shield sleeve, and spacer. Solder the pin to the center conductor. Insert the pin into the pin insulator, then screw the main body onto the retaining nut. Wrap the braid around the tail of the body and crimp the ring with a 0.213” hex crimp tool (or one labeled for use with RG-58 cable). Use heat shrink to cover crimp. Use the nut and washer to secure the connector to a case. SHRINK WRAP NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 2. DIMENSIONS APPLY AFTER FINISHING. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE CONREVSMA005-R58 ASSEMBLY INSTRUCTIONS 1. 2. 3. STRIPPED CABLE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 RP-SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG58 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 29-JUN-12 ENGR: S.HOGAN DT: 29-JUN-12 SCALE: 2:1 REV CONREVSMA005-R58 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA005-R58 价格&库存
很抱歉,暂时无法提供与“CONREVSMA005-R58”相匹配的价格&库存,您可以联系我们找货
