CONREVSMA006.031
CONREVSMA006.031
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA006.031 数据手册
Description Body Pin Insulation Washer Nut Material Brass Brass PTFE Brass Brass 1/4-36UNS-2A THREADS Finish Nickel Gold N/A Nickel Nickel 0.040 [1.02] REVISIONS REV B DESCRIPTION Updated footprint and dimensions; Added new title block 0.040 [1.02] TOP VIEW FLAT 0.228 [5.80] 0.179 [4.54] 0.039 [1.00] 0.04 [1.02] 0.375 [9.60] 0.160 [4.06] 0.060 [1.52] Ø0.402 [10.20] 0.065 [1.65] 0.160 [4.06] NUT 0.100 [2.54] TOP RECOMMENDED FOOTPRINT BACK VIEW 0.234 [6.00] Plastic/Metal Case Ø0.256 [6.50] 0.020 [0.50] Serves as rear flange WASHER RECOMMENDED MOUNTING HOLE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: BOTTOM Flange hides hole MOUNTING METHODS NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE 0.100 [2.54] 0.200 [5.08] Clamps into molded case Clamps into molded case Ø0.311 [7.90] H0.315 [8.00] 1/4-36UNS-2B THREADS 0.060 [1.52] SAH 0.240 [6.10] 0.152 [3.90] SIDE VIEW 0.037 [0.94] 0.157 [4.00] 0.075 [1.90] 0.786 [20.40] 29-JUN-12 Ø0.051 [1.30] Ø0.327 [8.30] Ø0.228 [5.80] 0.375 [9.60] APPV Use of nut optional Ø0.051 [1.30] 0.175 [4.50] DATE FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 RP-SMA FEMALE EDGE MULTI-MOUNT FOR 0.031” THICK BOARD SIZE DWG. NO. DRAWN: B.MURPHY DT: 29-JUN-12 ENGR: S.HOGAN DT: 29-JUN-12 SCALE: 2:1 REV CONREVSMA006.031 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA006.031 价格&库存
很抱歉,暂时无法提供与“CONREVSMA006.031”相匹配的价格&库存,您可以联系我们找货
