SMB7H-J-P-H-ST-TH2
SMB7H-J-P-H-ST-TH2
    SAMTEC(申泰)
    插件
    SMB
SMB7H-J-P-H-ST-TH2 数据手册
REVISION D DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] "A" SMB7H-J-P-X-ST-THX GENDER -J: JACK DO NOT SCALE FROM THIS PRINT TERMINATION -TH1: THROUGH HOLE WITH 0.90 POST -TH2: THROUGH HOLE WITH 0.51 POST TYPE -P: PCB 6.35 .250 REF ORIENTATION -ST: STRAIGHT PLATING (VALUES GIVEN IN MICRO-INCHES) -H: HEAVY GOLD 30 AU / 50 NI ON CENTER CONTACT 3 AU / 50 NI ON OUTER CONTACT (SEE TABLE 1) "A" C 0.98±0.10 .039±.004 3.68 .145 REF +0.10 0.00 3.40 C +.004 .134 - .000 6.35 .250 REF SMB7-INS-001 11.43 .450 REF SMB7H-J-P-X-ST-TH1-SHL (SEE TABLE 1) 3.44 .135 REF RECOMMENDED PCB LAYOUT SMB7-PIN-XXX-X (SEE TABLE 1 & 2) 5.08 .200 REF (TYP) SECTION "A"-"A" 5.08 .200 REF (TYP) 5.08 .200 (TYP) 1.60 .063 (4 PLCS) PTH "A" REF 1.02 .040 REF (4 PLCS) 5.08 .200 (TYP) "B" PTH F:\DWG\MISC\MKTG\SMB7H-J-P-X-ST-THX-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE FOR INSULATOR: 35.58 N [8.0 LB] . 3. MINIMUM PUSHOUT FORCE FOR CENTER CONTACT: 17.79 N [4.0 LB]. 4. SEE PACKAGING STANDARD CO-HD-WI-3040-M. 5. NOTE DELETED. DECIMALS ANGLES .X: 0.3 [.01] 5 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING CONTACT, SHELL: BRASS INSULATOR: PTFE PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND SHEET SCALE: 5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: SMB7 STRAIGHT THROUGH HOLE JACK- 75 OHM DWG. NO. SMB7H-J-P-X-ST-THX BY: G. HERMAN 03/25/2008 SHEET 1 OF 1
SMB7H-J-P-H-ST-TH2 价格&库存
很抱歉,暂时无法提供与“SMB7H-J-P-H-ST-TH2”相匹配的价格&库存,您可以联系我们找货
SMB7H-J-P-H-ST-TH2
    • 1+44.75520
    • 200+17.86320
    • 500+17.26920
    • 1000+16.96680
