CONREVSMA015-R178
CONREVSMA015-R178
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA015-R178 数据手册
Description Body Pin Insulation O Ring Washer Nut Spacer Support Heat Shrink Material Brass BE CU PTFE Si Rubber Brass Brass PTFE Brass Polyolefin Finish Nickel Gold N/A Rubber Nickel Nickel N/A Nickel Black REVISIONS RECOMMENDED MOUNTING HOLE REV DESCRIPTION DATE A B Add heat shrink, new frame, revised stripping instruct./dims Updated dimensions; Added new title block Ø0.256 (6.50) Ø0.118 (3.00) 0.787 (20.00) FLAT 0.228 (5.80) PIN Ø0.020 (0.50) Ø0.102 (2.60) SPACER Ø0.024 (0.60) 0.673 (17.10) 0.083 (2.10) Ø0.358 (9.10) 0.472 (12.00) 0.980 (24.90) CONREVSMA015-R178 ASSEMBLY INSTRUCTIONS 1. Strip the cable to the recommended dimensions. 2. Slip heat shrink over stripped cable. 3. Solder the support onto the braid. 4. Place the spacer onto the center conductor. 5. Solder or crimp the pin onto the center conductor. 6. Insert the pin, center conductor, spacer, and support into the body until the top of the pin is even with the body. 7. Crimp the tail of the body onto the support with a 0.093” hex crimp tool. 8. Use heat shrink to cover crimp. RECOMMENDED CABLE STRIPPING DIMENSIONS 0.197 0.032 (5.00) (0.80) 0.197 (5.00) RG-178 Cable Ø0.236 (6.00) NUT H0.315 (8.00) 1/4-36UNS-2B THREADS Ø0.402 (10.20) 0.055 (1.40) 0.020 (0.50) 0.065 (1.65) NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: SUPPORT Ø0.049 (1.24) WASHER O-RING 0.228 (5.80) CJ SAH 0.236 (6.00) 1/4-36UNS-2A THREADS 1/4-36UNS-2A THREADS 4/27/10 11-JUL-12 HEAT SHRINK SIDE VIEW H0.433 (11.00) APPV PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 MERLIN, OR 97532 TITLE: RP-SMA FEMALE BULKHEAD MOUNT CABLE END CRIMP WITH O-RING FOR RG178 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONREVSMA015-R178 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA015-R178 价格&库存
很抱歉,暂时无法提供与“CONREVSMA015-R178”相匹配的价格&库存,您可以联系我们找货
