CONMCX005
CONMCX005
    LINXTECHNOLOGIES(灵思)
    MCX
CONMCX005 数据手册
Description Body Socket Insulation Crimp Ring Washer Nut Heat Shrink Material Brass BE CU PTFE Brass Brass Brass Polyolefin Finish Gold Gold N/A Gold Gold Gold Black RECOMMENDED MOUNTING HOLE B SAH SOCKET PIN CHUCK 0.244 (6.20) 0.276 (7.00) Ø0.037 (0.95) CONMCX005 ASSEMBLY INSTRUCTIONS WASHER NUT 0.378 (9.60) Ø0.154 (3.90) 0.2x2x2 GROOVE 0.272 (6.90) 0.571 (14.50) 1. 2. 3. 4. 5. Ø0.377 (9.57) H0.250 (6.35) 6. 7. 10-56 UNS-2B THREADS RECOMMENDED CABLE STRIPPING DIMENSIONS RG-174 Cable CRIMP RING 0.787 (20.00) H0.250 (6.35) 0.197 (5.00) APPV Ø0.197 (5.00) Ø0.187 (4.75) Ø0.102 (2.60) 0.134 (3.40) DATE Added new title block and heat shrink; Updated instructions 11-JUL-12 FLAT 0.173 (4.40) FLAT 0.173 (4.40) 0.079 (2.00) DESCRIPTION HEAT SHRINK SIDE VIEW 10-56 UNS-2A THREADS REVISIONS REV 0.055 (1.40) 0.020 (0.50) Strip the cable to the recommended dimensions. Slip heat shrink and crimp ring over stripped cable Solder the socket to the center conductor. Insert the socket, center conductor, and insulator into the body until the socket snaps in. Wrap the braid around the tail of the body and crimp the ring with a 0.128” hex crimp tool(or one labeled for use with RG-174 cable). Use heat shrink to cover crimp. Use the nut and washer to secure the connector to a case. NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: 159 ORT LANE MERLIN, OR 97532 MCX FEMALE BULKHEAD MOUNT CABLE END CRIMP FOR RG174 CABLE SIZE DWG. NO. DRAWN: B.MURPHY DT: 11-JUL-12 ENGR: S.HOGAN DT: 11-JUL-12 SCALE: 2:1 REV CONMCX005 DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONMCX005 价格&库存
很抱歉,暂时无法提供与“CONMCX005”相匹配的价格&库存,您可以联系我们找货
