Description
Body
Socket
Insulation
Washer
Gasket
Crimp Ring
Insulator
Cover
Heat Shrink
Material
Brass
BE CU
PTFE
PH Bronze
SI Rubber
Brass
PTFE
Brass
Polyolefin
Finish
Nickel
Gold
N/A
Nickel
Rubber
Nickel
N/A
Nickel
Black
REVISIONS
REV
B
DESCRIPTION
Added new title block, heat shrink and instructions;
updated cover and insulator drawings
0.650
[16.50]
0.051
[1.30]
APPV
2-JUL-12
SAH
Ø0.256
[6.50]
0.331
[8.40]
0.287
[7.30]
0.055
[1.40]
DATE
0.500
[12.70]
Ø0.185
[4.70]
Ø0.146
[3.70]
COVER
0.287
[7.30]
1/4-36UNS-2B
THREADS
Ø0.287
[7.30]
INSULATOR
CONREVSMA012-R58 ASSEMBLY INSTRUCTIONS
0.276
1. Strip cable to recommended dimensions.
[7.00]
2. Slip heat shrink and crimp ring onto stripped cable.
2. Slide the cable into the body until the center conductor
is centered in the fork.
3. Push the braided shield over the barrel.
4. Solder the center conductor into the center of the fork.
5. Slide the crimp ring over the shield and crimp with a 0.213”
hex crimp tool (or one labeled for use with RG-58 cable).
6. Trim off any excess shield wire sticking out from the ring.
7. Slip the heat shrink over the crimp ring until it is against
the body and shrink.
8. Insert insulator into body.
9. Push the cover into the opening.
0.098 0.177
(2.50) (4.50)
CRIMP RING
0.256
(6.50)
RG-58 Cable
BARREL
RECOMMENDED CABLE STRIPPING DIMENSIONS
HEAT SHRINK
Ø0.177
[4.50]
Ø0.260
[6.60]
SIDE VIEW
NOTES: (UNLESS OTHERWISE SPECIFIED)
1. ALL DIMENSIONS ARE IN INCHES [mm].
2. DIMENSIONS APPLY AFTER FINISHING.
3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE.
4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM.
: THIS DRAWING CONTAINS PROPRIETARY INFORMATION
THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE
TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS
DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE
EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS
DESIGNATED AGENTS.
MATERIAL:
BRAIDED SHIELD
0.984
[25.00]
Ø0.124
[3.15]
FINISH:
PROJECTION:
TOLERANCES:
.020 [0.50]-.200 [5.00]= .008 [0.20]
.200 [5.00]-1.200 [30.00]= .016 [0.40]
1.20 [30.0]-4.75 [120.0]= .024 [0.60]
4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1
DRAWN: B.MURPHY DT: 2-JUL-12
ENGR: S.HOGAN
DT: 2-JUL-12
TITLE:
159 ORT LANE
MERLIN, OR 97532
RP-SMA MALE RIGHT ANGLE
CABLE END CRIMP FOR RG58 CABLE
SIZE DWG. NO.
REV
CONREVSMA012-R58
SCALE: 2:1
DO NOT SCALE DRAWING
B
SHEET 1 OF 1
LDCFDLT_A
很抱歉,暂时无法提供与“CONREVSMA012-R58”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+63.61200
- 200+25.38000
- 500+24.53760
- 1000+24.11640
