MCX Crimp Type Right Angle Plugs for Flexible Cable – 50 Ohm
1. Identify connector parts. (4 piece parts except RG-58)
2. Strip cable to dimensions shown. Do not nick braid or center
conductor. A wire stripper of correct size is recommended for
this step. Twist stranded center conductor into tight bundle
and tin (optional). Slide crimp sleeve onto cable shown.
3. Flair braid and slide cable into body making certain that the
cable insulation bottoms on center contact. Arrange braid
uniformly around crimp stem. Slide crimp sleeve over braid
and crimp securely using recommended crimp tool.
4. Solder center conductor to contact through rear access port.
Use a minimum amount of solder for a full fillet joint. .020
(0.51) diameter solder is recommended.
5. Assemble insulator, if applicable; then place expansion cap in
access port and seat with .156 (3.96) diameter flat punch or
MCX hand assembly tool 141-0000-908. Shrink heat shrink
tubing over crimp sleeve if applicable.
Cable Group
Part No.
“A”
“B”
“C”
Crimp Hex
RG-178/U, 196
133-3402-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.105 (2.67)
RG-188/U, 316, 161, 174
133-3403-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.128 (3.25)
RG-316 DS, 188 DS
133-3404-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.151 (3.83)
RG-179/U, 187
133-3433-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.128 (3.25)
RG-178/U, 196
133-5402-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.105 (2.67)
133-5403-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.128 (3.25)
RG-316 DS, 188 DS
133-5404-101/106
.050 (1.27)
.270 (6.86)
.200 (5.08)
.151 (3.83)
RG-58/U, 303, 141
133-3407-101/106
.067 (1.70)
.295 (7.49)
.210 (5.33)
.213 (5.41)
230
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“133-3402-106”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+54.05081250+7.00602
