142-0694-031
142-0694-031
    CINCH
    SMA
142-0694-031 数据手册
SMA Right Angle Solder Type Plug for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. Bevel the cable center conductor per contact detail of SMA interface on page 48. Slide coupling nut onto cable as shown. Cable Group Part No. RG-402/U (.141 Semi-Rigid) 142-0694-021 142-0694-026 142-0694-041 142-0694-046 3. Insert cable into body making sure cable jacket is bottomed against shoulder inside of body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Trim expanded insulation flush with front of body or fixture body and cable during soldering to prevent insulation expansion. 4. Thread coupling nut over body. SMA Solder Type Straight Plugs for Semi-Rigid Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. Bevel the cable center conductor per contact detail of SMA interface on page 48. Cable Group Part No. RG-402/U (.141 Semi-Rigid) 142-0694-031 142-0694-036 3. 3. Insert cable into body making sure cable jacket is flush with front of body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Trim expanded cable insulation flush with front of body or fixture body and cable during soldering to prevent insulation expansion. 4. Snap “C” spring onto connector body groove. Compress “C” spring using 141-0000904 compression tool. Install coupling nut onto connector body. Nut should spin freely. 235 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0694-031 价格&库存
很抱歉,暂时无法提供与“142-0694-031”相匹配的价格&库存,您可以联系我们找货
