CONREVSMA006.062SQ
CONREVSMA006.062SQ
    LINXTECHNOLOGIES(灵思)
    SMA(DO-214AC)
    RP-SMA
CONREVSMA006.062SQ 数据手册
Description Body Pin Insulation Washer Nut Material Brass Brass PTFE Brass Brass 1/4-36UNS-2A THREADS Finish Nickel Gold N/A Nickel Nickel REVISIONS 0.040 [1.02] REV B 0.065 [1.65] 0.039 0.179 [1.00] [4.54] 0.043 [1.09] 0.175 [4.50] 0.152 [3.90] Clamps into molded case Ø0.402 [10.20] Flange hides hole 0.240 [6.10] Ø0.256 [6.50] SIDE VIEW RECOMMENDED MOUNTING HOLE Plastic/Metal Case Ø0.311 [7.90] S0.325 [8.30] 0.020 [0.50] BACK VIEW Serves as rear flange WASHER MOUNTING METHODS 0.060 [1.52] NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE. 2. DIMENSIONS APPLY AFTER FINISHING. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. : THIS DRAWING CONTAINS PROPRIETARY INFORMATION 159 ORT LANE 0.100 [2.54] 0.200 [5.08] 0.100 [2.54] THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. MATERIAL: BOTTOM NUT 0.157 [4.00] 0.234 [6.00] 0.786 [20.40] 0.160 [4.06] SAH 0.067 [1.70] 0.375 [9.60] 0.375 [9.60] 29-JUN-12 Clamps into molded case Ø0.051 [1.30] 0.04 [1.02] APPV H0.315 [8.00] 0.040 [1.02] TOP VIEW DATE Use of nut optional 1/4-36UNS-2B THREADS FLAT 0.228 [5.80] 0.060 [1.52] Updated footprint and dimensions; Added new title block Ø0.051 [1.30] Ø0.327 [8.30] Ø0.228 [5.80] 0.160 [4.06] DESCRIPTION TOP RECOMMENDED FOOTPRINT FINISH: PROJECTION: TOLERANCES: .020 [0.50]-.200 [5.00]= .008 [0.20] .200 [5.00]-1.200 [30.00]= .016 [0.40] 1.20 [30.0]-4.75 [120.0]= .024 [0.60] 4.75 [120.0]-12.40 [315.0]= .040 [1.0] ANGLES: 1 TITLE: MERLIN, OR 97532 RP-SMA FEMALE EDGE MULTI-MOUNT W/ SQUARE FLANGEFOR 0.062” THICK BOARD SIZE DWG. NO. DRAWN: B.MURPHY DT: 29-JUN-12 ENGR: S.HOGAN DT: 29-JUN-12 SCALE: 2:1 REV CONREVSMA006.062SQ DO NOT SCALE DRAWING B SHEET 1 OF 1 LDCFDLT_A
CONREVSMA006.062SQ 价格&库存
很抱歉,暂时无法提供与“CONREVSMA006.062SQ”相匹配的价格&库存,您可以联系我们找货
