MCX-J-C-H-ST-CA1
MCX-J-C-H-ST-CA1
    SAMTEC(申泰)
    MCX
MCX-J-C-H-ST-CA1 数据手册
REVISION M DO NOT SCALE FROM THIS PRINT MCX-J-C-X-ST-CA1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] Pb THIS PRODUCT MANUFACTURED WITH LEAD-FREE PROCESSING GENDER -J: JACK TERMINATION -CA1: CABLE (RG174 OR RG316) TYPE -C: CABLE ORIENTATION -ST: STRAIGHT PLATING SPECIFICATION -H: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT (SEE TABLE 1) 3 1 0.96 .038 REF 2 3.90 .154 REF 4.50 .177 REF 7.50 .295 REF 7.00 .276 REF 15.50 .610 REF F:\DWG\MISC\MKTG\MCX-J-C-X-ST-CA1-MKT.SLDDRW NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. CENTER CONTACT PUSHOUT FORCE: 10 N [2.25 LB] MIN. 3. NOTE DELETED. 4. NOTE DELETED. 5. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. 6. NOTE DELETED. 7. NOTE DELETED. 8. NOTE DELETED. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS PROPRIETARY NOTE * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS ANGLES .X: 0.3 [.01] 5 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * THIS DOCUMENT CONTAINS CONFIDENTIAL AND AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL, FERRULE: BRASS CONTACT: COPPER ALLOY DIELECTRIC: PTFE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY SHEET SCALE: 6:1 DESCRIPTION: MCX STRAIGHT CABLE JACK, RG174 & RG316- 50 OHM DWG. NO. BY: MCX-J-C-X-ST-CA1 R MUSSER 02/06/2008 SHEET 1 OF 2 REVISION M C 2.60±0.30 .102±.012 5.00±0.30 .197±.012 C 10.10±0.30 .398±.012 2.68 .106 REF TO INSULATOR RG-174 OR RG-316 CABLE C 1 IN-PROCESS 1 STRIP AND TIN INNER CONDUCTOR HST-0.125-02-BLK 2.58 .102 REF TO CENTER CONTACT IN-PROCESS 2 ADD HEAT SHRINK TUBE AND FERRULE DETAIL 'A' SCALE 6 : 1 20.0±2.5 .79±.10 0.10 .004 MAX ALLOWABLE GAP C 2 IN-PROCESS 3 SOLDER SIGNAL SOCKET 2.30 .091 (MIN. FLARED ID) 0.45 .018 REF IN-PROCESS 4 FLARE SHIELD DETAIL 'B' SCALE 8 : 1 3 'B' IN-PROCESS 5 ADD SUB ASSEMBLY 'A' 0.25 .010 MAX ALLOWABLE GAP C IN-PROCESS 6 3.25 .128 HEX CRIMP C (ACROSS 2 FACES) CRIMP FERRULE (USE RF CRIMP HAND TOOL# CAT-RF-FER-01 OR EQUIVALENT) (USE .128" HEX DIE) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 0.6 [0.03] MAX GAP ALLOWABLE REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. IN-PROCESS 7 APPLY HEAT SHRINK TUBING F:\DWG\MISC\MKTG\MCX-J-C-X-ST-CA1-MKT.SLDDRW DO NOT SCALE DRAWING SHEET SCALE: 1:0.666667 DESCRIPTION: MCX STRAIGHT CABLE JACK, RG174 & RG316- 50 OHM DWG. NO. BY: MCX-J-C-X-ST-CA1 R MUSSER 02/06/2008 SHEET 2 OF 2
MCX-J-C-H-ST-CA1 价格&库存
很抱歉,暂时无法提供与“MCX-J-C-H-ST-CA1”相匹配的价格&库存,您可以联系我们找货
