SMA Solder Type Straight Plugs for Semi-Rigid Cable
1. Identify connector parts. (3 piece parts)
2. Strip cable to dimensions shown. Do not nick center conductor. Slide
coupling nut onto cable as shown.
3. Place center contact on center conductor making sure contact bottoms
against cable insulation. Solder center conductor to center contact through
solder hole. Solder must not be allowed to run on outside of contact. Use
a minimum amount of solder for a good joint. .020 (0.51) diameter solder is
recommended. Trim excess insulation.
4. Insert contact and cable into body making sure cable is bottomed against
insulator in body. Solder body to cable. Use a minimum amount of heat to
minimize cable insulation movement.
5. Thread coupling nut over body
Cable Group
Part No.
“A”
RG-405/U (.086 Semi-Rigid)
142-0693-051
142-0693-056
.070 (1.78)
.070 (1.78)
RG-402/U (.141 Semi-Rigid)
142-0694-051
142-0694-056
.085 (2.16).
085 (2.16)
SMA Solder Type Antenna Connector Plug for Flexible or
Semi-Rigid Cable
1. Identify connector parts. (2 piece parts)
2. Strip cable to dimensions shown. Do not nick center conductor or braid
on flexible cable.
3. Flexible Cable Attachment: Twist stranded center conductor into
tight bundle and tin (optional). Slide cable into body, making sure cable
insulation bottoms on center contact and braid fits inside stem. Solder
center conductor to contact through the side access ports. Use a
recommended. Solder braid to body. Use a minimum amount of solder to
completely join the braid to the body. Semi-Rigid Cable Attachments:
Slide cable into body making certain cable insulation bottoms on center
contact. Solder center conductor to contact through the side access
ports. Use a minimum amount of solder for a good joint. .020 (0.51)
diameter solder is recommended. Solder body to cable jacket. Use a
minimum amount of heat to minimize cable insulation movement.
Cable Group
RG-178/U, .047 Semi-Rigid
236
Part No.
142-0801-421
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0693-051”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+150.557971+19.53477
- 10+127.9162410+16.59703
- 25+119.9041625+15.55747
- 50+114.1791450+14.81465
- 100+108.73045100+14.10769
- 250+101.92835250+13.22512
- 500+97.06880500+12.59460
- 1000+92.442421000+11.99433
