REVISION B
Pb THIS PRODUCT MANUFACTURED
WITH LEAD-FREE PROCESSING
MMCXV-J-P-XX-ST-TH1
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
TERMINATION
-TH1: THROUGH HOLE
SERIES
-V: HIGH VIBRATION 50 OHM
DO NOT
SCALE FROM
THIS PRINT
ORIENTATION
-ST: STRAIGHT
GENDER
-J: JACK
PLATING SPECIFICATION
-HF: 30µ" GOLD CENTER CONTACT,
3µ" GOLD OUTER CONTACT
-GF: 10µ" GOLD CENTER CONTACT,
(SEE TABLE 1)
TYPE
-P: PCB
4.50 .177 REF
0.28 .011 REF
3.50 .138
REF
DETAIL 'B'
SCALE 16 : 1
'B'
3.50 .138 REF
2.30 .091
REF
"A"
1
1.50±0.10 .059±.004
C
CL
2
2.70 .106
REF
3
RECOMMENDED PCB LAYOUT
0.40 .016 REF
(TYP)
1.65 .065
REF (TYP)
7.40 .291
REF (TYP)
POSITION INSULATOR
FLUSH TO SHELL +/-0.08
C
2.54 .100
(TYP)
0.84±0.05 .033±.002 (PTH)
(5 PLCS)
3.05 .120
REF (TYP)
"A"
0.50 .020
REF (TYP)
NOTES:
2.54 .100
REF
0.70 .028 REF
SECTION "A"-"A"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN
MILLIMETERS [INCHES].
TOLERANCES ARE:
DECIMALS
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE FOR INSULATOR: 22.24N [5.0 LBS].
3. MINIMUM PUSHOUT FORCE FOR CENTER CONTACT: 11.12N [2.5 LBS].
4. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-HD-WI-3040-M.
TRAY: TY-SMA001-1
COVER: TY-SMA001-2
200 PARTS PER TRAY (2 PARTS PER POCKET)
F:\DWG\MISC\MKTG\MMCXV-J-P-XX-ST-TH1-MKT.SLDDRW
2.54 .100
(TYP)
ANGLES
X.X: 0.3 [.01]
5
X.XX: 0.13 [.005]
X.XXX: 0.051 [.0020]
MATERIAL:
DO NOT SCALE DRAWING
SHELL: BRASS
SOCKET: BeCu
INSULATOR: PTFE
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
SHEET SCALE: 8:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
MMCXV ST THROUGH HOLE, JACK, HIGH VIBRATION 50 OHM
DWG. NO.
MMCXV-J-P-XX-ST-TH1
BY: ALVINW
10/08/2011
SHEET 1 OF 2
REVISION B
CL
POSITION INSULATOR
C
IN PROCESS 1
INSERT INSULATOR
PROPRIETARY NOTE
SHEET SCALE: 8:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
MMCXV-J-P-XX-ST-TH1
BY: ALVINW
10/08/2011
SHEET 2 OF 2
MMCXV-J-P-HF-ST-TH1 价格&库存
很抱歉,暂时无法提供与“MMCXV-J-P-HF-ST-TH1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+66.596211+8.64527
- 25+57.6949425+7.48974
- 50+36.7737250+4.77383
- 100+26.75869100+3.47372
- 500+26.33338500+3.41850
- 国内价格
- 1+54.87480
- 10+53.78400
- 30+53.06040
