916A524
916A524
    WINCHESTER(温彻斯特)
    SMA(DO-214AC)
    CONN SMA PLUG STR 50 OHM SOLDER
916A524 数据手册
SMA Connectors _____________________________ Panel Mount Types Bulkhead Jack Front Mount Drawing P/N: 926A515 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Bulkhead Jack Rear Mount, Large Flange Drawing P/N: 921A 5114 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Bulkhead Jack Rear Mount, Small Flange Drawing P/N: 921A504 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 34 s - Page 35 - SMA Connectors _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Solder Pot Terminal P/N: 916A524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Plug 2 Hole Rectangular Flange Solder Pot Terminal P/N: 916B524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 4 Hole Square Flange Drawing Solder Pot Terminal P/N: 917A524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 2 Hole Rectangular Flange Drawing Solder Pot Terminal P/N: 917B524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 35 s - Page 36 - SMA Connectors _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Long Rear Insulator - Solder Pot Terminal P/N: 916A524L RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Plug 2 Hole Rectangular Flange Drawing Long Rear Insulator - Solder Pot Terminal P/N: 916B524L RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 4 Hole Square Flange Drawing Long Rear Insulator - Solder Pot Terminal P/N: 917A524L RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 2 Hole Rectangular Flange Drawing Long Rear Insulator - Solder Pot Terminal P/N: 917B524L RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 36 s - Page 37 - SMA Connectors _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Blunt Post Solder Pot Terminal P/N: 916A524B RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Plug 2 Hole Rectangular Flange Drawing Blunt Post Solder Pot Terminal P/N: 916B524B RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 4 Hole Square Flange Drawing Blunt Post Solder Pot Terminal P/N: 917A524B RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 2 Hole Rectangular Flange Drawing Blunt Post Solder Pot Terminal P/N: 917B524B RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index s - Page 38 - SMA Connectors 37 _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Slotted Terminal P/N: 916AS524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Plug 2 Hole Rectangular Flange Drawing Slotted Terminal P/N: 916BS524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 4 Hole Square Flange Drawing Slotted Terminal P/N: 917AS524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Index Back to 38 s - Page 39 - SMA Connectors _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Half-Round Terminal P/N: 916AH524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Plug 2 Hole Rectangular Flange Drawing Half-Round Terminal P/N: 916BH524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 4 Hole Square Flange Drawing Half-Round Terminal P/N: 917AH524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 2 Hole Rectangular Flange Drawing Half-Round Terminal P/N: 917BH524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 39 s - Page 40 - SMA Connectors _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Terminal Flush to Flange Base P/N: 916AF524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Drawing Panel Mount Types Panel Mount Plug 2 Hole Rectangular Flange Terminal Flush to Flange Base P/N: 916BF524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Drawing Panel Mount Types Panel Mount Jack 4Hole Square Flange Terminal Flush to Flange Base P/N: 917AF524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Drawing Panel Mount Types Panel Mount Jack 2 Hole Rectangular Flange Terminal Flush to Flange Base P/N: 917BF524 RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 s - Page 41 - Back to Index 40 SMA Connectors _____________________________ Panel Mount Types Panel Mount Plug 4 Hole Square Flange Drawing Flat Tab Terminal P/N: 916A524FT RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Drawing Panel Mount Types Panel Mount Plug 2 Hole Square Flange Flat Tab Terminal P/N: 916B524FT RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 4 Hole Square Flange Drawing Flat Tab Terminal P/N: 917A524FT RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ Panel Mount Types Panel Mount Jack 2 Hole Rectangular Flange Flat Tab Terminal P/N: 917B524FT Drawing RoHS compliant REQUEST QUOTE REQUEST DRAWING _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Index s - Page 42 - Back to 41
916A524 价格&库存
很抱歉,暂时无法提供与“916A524”相匹配的价格&库存,您可以联系我们找货
