SMA-J-P-H-ST-PN2
SMA-J-P-H-ST-PN2
    SAMTEC(申泰)
    SMA
SMA-J-P-H-ST-PN2 数据手册
REVISION D SMA-J-P-X-ST-PN2 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] "A" GENDER -J: JACK DO NOT SCALE FROM THIS PRINT TERMINATION -PN2: PANEL MOUNT TYPE -P: PCB 'B' 0.84 .033 PLATING SPECIFICATION -H: HEAVY GOLD (SEE TABLE 1) DETAIL 'B' SCALE 8 : 1 "A" +0.20 4.63 .182 REF 1/4-36 UNS-2A (REF) SEE NOTE 1 +.009 DETAIL 'C' SCALE 8 : 1 INSULATOR (SMA-INS-006) 'D' SOCKET (SMA-J-P-X-ST-PN2-SKT) 1.65 .065 REF 2.59 .102 (2 PLCS) REF +0.23 C3 0.03 - 0.03 .001 - .001 TO CENTER CONTACT SHELL (SMA-J-P-X-ST-PN2-SHL) 'C' 9.52 .375 REF +.008 C2 0.05 - 0.05 .002 - .002 TO INSULATOR 1.93 .076 REF 6.33 .249 REF ORIENTATION -ST: STRAIGHT C1 15.88 .625 REF SECTION "A"-"A" RECOMMENDED PCB LAYOUT 12.22 .481 12.22 .481 REF 0.11 .004 (TYP) (4 PLCS) DETAIL 'D' SCALE 6 : 1 NOTES: C4 C5 4.25 .167 2.60 .102 (2 PLCS) 5.66 .223 REF 1. C REPRESENTS A CRITICAL DIMENSION. 2. STAKE AROUND CIRCUMFERENCE 4 INDENTSEQUALLY SPACED. 3. PUSHOUT FORCE FOR INSULATOR: 44.48 N[10 LB] MIN. 4. CENTER CONTACT PUSHOUT FORCE: 13.35 N [3 LB] MIN. 5. PARTS TO BE PACKAGED IN TRAYS; IF QUANTITY IS LESS THAN HALF TRAY, PARTS TO BE PACKAGED IN COHESIVE FOAM 6. RoHs COMPLIANT. F:\DWG\MISC\MKTG\SMA-J-P-X-ST-PN2-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: SEE TABLE 1 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: SMA STRAIGHT, PANEL MOUNT JACK- 50 OHM DWG. NO. SMA-J-P-X-ST-PN2 BY: R MUSSER 01/28/2008 SHEET 1 OF 1
SMA-J-P-H-ST-PN2 价格&库存
很抱歉,暂时无法提供与“SMA-J-P-H-ST-PN2”相匹配的价格&库存,您可以联系我们找货
SMA-J-P-H-ST-PN2
    • 1+118.46520
    • 200+47.27160
    • 500+45.69480
    • 1000+44.91720
