MMCX-P-P-H-RA-TH1
MMCX-P-P-H-RA-TH1
    SAMTEC(申泰)
    插件
    MMCX-P-P-H-RA-TH1
MMCX-P-P-H-RA-TH1 数据手册
REVISION E MMCX-P-P-X-RA-TH1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER -P: PLUG "A" DO NOT SCALE FROM THIS PRINT TERMINATION -TH1: THROUGH HOLE TYPE -P: PCB 3.80 .150 REF 2.05 .081 REF SURFACES FLUSH +/-.10 ORIENTATION -RA: RIGHT ANGLE PLATING SPECIFICATION -H: HEAVY GOLD (SEE TABLE 1) 1.80 .071 REF "A" 0.50 .020 REF DETAIL 'B' SCALE 20 : 1 2.54 .100 REF 0.41 .016 REF 1.62 .064 REF +0.05 2.38 .094 REF +.002 0.20 - 0.20 .008 - .008 TO CENTER CONTACT MMCX-P-P-X-RA-TH1-PIN MMCX-SHL-002-X MMCX-CRNG-001-X 1.70 .067 (REF) 5.25 .207 REF 7.00 .276 MMCX-INS-005 (INSULATOR 1) (SEE NOTE 2) 'B' MMCX-INS-003 (INSULATOR 2) RECOMMENDED PCB LAYOUT MMCX-BDY-002 0.84±0.05 .033±.002 (TYP) 0.72 .028 REF NOTES: 3.50 .138 (REF) 1. C REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR INSULATOR #1 ONLY: 22.24 N [5 LB] MIN. 3. PUSHOUT FORCE FOR CENTER CONTACT: 11.12 N [2.5 LB] MIN. 4. INSERTION AND WITHDRAWAL FORCES PER 2.2.2 OF EN 122340:2002. INSERTION = 18 N[4 LB] MAX. WITHDRAWAL = 6 N[1.3 LB] MIN. / 18 N[4 LB] MAX. 4. PARTS TO BE PACKAGED IN TRAYS; IF QUANITY IS LESS THAN HALF TARY, PARTS TO BE PACKAGED IN COHESIVE FOAM. 5. RoHs COMPLIANT. 2.10 .083 REF 2.54 .100 SURFACES FLUSH +/-.10 2.54 .100 SECTION "A"-"A" F:\DWG\MISC\MKTG\MMCX-P-P-X-RA-TH1-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: SEE TABLE 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 6:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MMCX RIGHT ANGLE, PLUG- 50 OHM DWG. NO. MMCX-P-P-X-RA-TH1 BY: R MUSSER 12/03/2007 SHEET 1 OF 1
MMCX-P-P-H-RA-TH1 价格&库存
很抱歉,暂时无法提供与“MMCX-P-P-H-RA-TH1”相匹配的价格&库存,您可以联系我们找货
MMCX-P-P-H-RA-TH1
  • 1+116.404581+15.05140
  • 25+111.7377425+14.44797
  • 50+107.2435250+13.86685
  • 100+99.75320100+12.89834
  • 250+96.92243250+12.53231
库存:60
