710A205F
710A205F
    WINCHESTER(温彻斯特)
    UHF CRIMP PLUG (RG58)
710A205F 数据手册
Specifications for UHF Connectors _____________________________ UHF style connectors are inexpensive, general purpose connectors with non-constant impedance for use at 500 volts or less, and for use with low frequencies to 200Mhz for best performance, or to 500MHz but with diminished performance. These coaxial connectors are widely used in citizens band communications, CCTV, public address systems, mobile radio equipment, civil defense, ship to shore communications, antenna connections, landing systems, and ground control apparatus. UHF connectors use a 5/8-24 threaded coupling. They are available in a wide selection of sizes to fit various cable sizes. s MATERIALS Connector Parts Connector Body and Parts Male Contact Pin Outer Contact Crimp Ferrule Insulators, Plating Material Brass Brass Brass Annealed Copper Delrin, Teflon Nickel ELECTRICAL Requirement Impedance Frequency Range VSWR Working Voltage (At Sea level) Insulation Resistance Contact Resistance Test Voltage Performance Non Constant 0-500MHz 1.25 Max. 750V rms 5000 Megohm Min. 5mW Max. 2000V rms MECHANICAL & ENVIRONMENTAL Requirement Durability Performance 500 Matings RG58 - 60 Lb. Min. Cable Retention (Cable Types) RG59 - 75 Lb. Min. RG8, 213 - 150 Lb. Min. Coupling Nut 45 lbs. Maximum Delrin: -55 to +85°C Temperature Range Teflon: -55 to +200°C s _____________________________ 22 FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 s - Page 23 - UHF Connectors _____________________________ Crimp Plugs UHF cable plugs are available in two-piece crimp and older versions. Several cable diameters are facilitated with these connectors for applicable applications. A reducing adapter is used for smaller cable sizes when using the solder types. Part Number RG/U Fig. Cable No. Description 710A205F Crimp Plug 58 106 710A205G Crimp Plug 59, 62 106 8, 213 107 58 108 58 108 710A908B Twist/Solder Plug, PL259 Reducing Adapter, UG175/U 770A508F Reducing Adapter, UG176/U 770A508G RoHS compliant DRAWING REQUEST QUOTE Fig. 106 Fig. 107 REQUEST Fig. 108 Jacks Two panel jack style are available as standard items. These panel jacks will facilitate any cable size by soldering the center conductor to the connector’s solder-cup contact. Part Number Description 726A508 Bulkhead Jack Any 109 727A508 Panel Jack, SO239 Type Any 110 RoHS compliant REQUEST QUOTE DRAWING Fig. 109 Fig. 110 RG/U Fig. Cable No. REQUEST s Adapters Standard configurations of adapters are machined brass with attractive nickel plating. All contacts are gold plated brass (males) and phosphor bronze (females). Part Number 731A505 Description Male/Male Fig. No. 111 732A508 Female/Female Inline 112 735A504 743A508 Female/Female, Bulkhead F/M/F “T” Adapter 113 114 745A508 F/F/F “T” Adapter 115 751A505 F/M Right Angle Adapter 116 RoHS compliant DRAWING REQUEST QUOTE REQUEST Fig. 111 Fig. 112 Fig. 113 Fig. 114 Fig. 115 Fig. 116 s _____________________________ FOR TECHNICAL SUPPORT: PHONE 973-347-4040 / FAX 973-347-2111 Back to Index 23
710A205F 价格&库存
很抱歉,暂时无法提供与“710A205F”相匹配的价格&库存,您可以联系我们找货
