135-9711-802
135-9711-802
    CINCH
    CONN MMCX JACK 50 OHM EDGE MNT
135-9711-802 数据手册
Non Magnetic Connectors Product Catalog belfuse.com/cinch NON-MAGNETIC RF CONNECTORS Introduction Johnson’s Non-Magnetic Connector Additions Offer Solutions to MR Imaging Technology Johnson, a product line of Cinch Connectivity Solutions, has expanded the connector product groups in its popular line of Non-Magnetic RF coaxial connectors and cable assemblies. MCX and MMCX micro-miniature connectors have been added to satisfy the needs of the RF coil manufacturers that are building smaller coils for MRI equipment. Customized flex coils and array coils can image smaller parts of the body such as wrists, feet, hands and other appendages. The Non-Magnetic MCX and MMCX is the perfect micro-miniature connector for small multichannel coil packages as they provide a positive snap-on coupling design with high mating cycles for rugged, high density connectivity. The Type N Non-Magnetic connector provides a perfect RF solution for high Tesla fields considered for future designs. These deep tissue MR images will require the rugged interface of the N connector as well as the tri-alloy plating to eliminate inter-modulation issues. All the connectors in Johnson’s Non-Magnetic line are made from high purity copper alloys assuring no ferrous materials are in the connectors manufactured. Cinch Connectivity Solutions continues to work with our customers to develop new solutions as the MR industry transitions to high-end field applications and improved resolution at greater physical depths within the body. Products are offered through authorized distributors and international sales channels including a direct sales force and a network of manufacturers’ representatives. For more information, please call (800) 247-8256. About Johnson Cinch Connectivity Solutions, located in Waseca, MN, manufactures Johnson® RF Connectors such as Ultra-miniature (UMC), Microminiature (MCX, MCX 75, MMCX and SMP), Sub-miniature (SMA, SMB, SMB Mini-75 Ohm, SMK) and Medium (Type N) in the most popular styles including PC Board Mount, End Launch, Bulkhead Mount and Cable Mounts (Flexible, Semi-rigid and Conformable). Table of Contents MMCX Non-Magnetic RF Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 MCX Non-Magnetic RF Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 SMA Non-Magnetic RF Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 SMB Non-Magnetic RF Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Type N Non-Magnetic RF Connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Assembly Instructions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 The Johnson Combination 2 MRI Connectors and Modular Customization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Competitor Cross Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 NON-MAGNETIC RF CONNECTORS MMCX Non-Magnetic RF Connectors ELECTRICAL SPECIFICATIONS Impedance: 50 Ohms Frequency Range 0-6 GHz VSWR: (f = GHz) .047 dia flexible RG-178, RG-316, RG-316 DS Working Voltage 170 VRMS at sea level Dielectric Withstanding Voltage 500 VRMS at sea level Insulation Resistance 1000 megohms minimum Contact Resistance (milliohms maximum) Center Contact (straight cabled connectors, uncabled receptacles) Center Contact (right angle cabled connectors) Outer Contact Braid to Body Corona Level: Straight Cable Connectors Right Angle Cable Connectors 1.20 1.20 1.14 + .07f 1.25 Initial After Environmental 5.0 5.0 1.0 1.5 8.0 15.0 1.5 N/A 190 volts min at 70,000 feet Insertion Loss(dB maximum, tested at 1 GHz) Straight Cable Connectors Right Angle Cable Connectors Uncabled Receptacles 0.1 0.2 N/A RF Leakage (dB minimum tested at 2.5 GHz) Flexible Cable Connectors RF High Potential Withstanding Voltage -60 dB tested at 4 and 7 MHz VRMS minimum 400 MECHANICAL SPECIFICATIONS Engagement Design Series MMCX Engagement Force 8 lbs. max axial engagement, 1.4 lbs. min axial disengagement Contact Retention 2.0 pounds min. axial force, 1 inch-ounce min. torque (uncabled receptacles) Cable Retention Connectors for .047 flexible Connectors for RG-178 Connectors for RG-316 Connectors for RG-316 DS Connectors for .086 Semi-Rigid *Or cable breaking strength whichever is less. Durability: Axial Force* (lbs) Torque (in-oz) 3.5 7.0 20.0 25.5 30.0 N/A N/A N/A N/A 16 500 cycles minimum ENVIRONMENTAL SPECIFICATIONS (Meets or Exceeds the Applicable Paragraph of MIL-RF-39012) Temperature Range Thermal Shock Corrosion Shock Vibration Moisture Resistance -65°C to +165°C MIL-STD-202, Method 107, Condition C (Except -55°C to 115°C) MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 213, Condition B MIL-STD-202, Method 204, Condition D MIL-STD-202, Method 106 belfuse.com/cinch 3 NON-MAGNETIC RF CONNECTORS MMCX Non-Magnetic RF Connectors For Flexible Cable and PC Mount Straight Crimp Type Plug - Solder or Crimp Contact - Captivated Contact Cable Type Gold Plated “A” “B” Termination RG-316/U, 188, 161, 174 135-9403-001 .509 (12.93) .173 (4.39) Crimp Sleeve RG-178/U, 196 135-9402-001 .462 (11.73) .137 (3.48) Crimp Insert .047 Dia. Flex 135-9436-001 .462 (11.73) .137 (3.48) Crimp Insert See assembly instructions page 22 Right Angle Crimp Type Plug - Captivated Contact Cable Type Gold Plated “A” “B” Termination RG-316/U, 188, 187, 179, 161, 174 135-9403-101 .412 (10.46) .334 (8.48) Crimp Sleeve RG-178/U, 196 135-9402-111 .412 (10.46) .334 (8.48) Crimp Sleeve .047 Dia. Flex 135-9436-101 .354 (8.99) .276 (6.98) Crimp Insert See assembly instructions page 23 Straight Jack Receptacle Gold Plated “A” 135-9701-201 .115 (2.92) 135-9701-211 .068 (1.73) Mounting hole layout figure 1 on page 5 4 NON-MAGNETIC RF CONNECTORS MMCX Non-Magnetic RF Connectors For PC Mount Right Angle Jack Receptacle Gold Plated “A” 135-9701-301 .155 (3.94) 135-9701-311 .068 (1.73) Mounting hole layout figure 1 on page 5 below End Launch Jack Receptacle - Surface Contact Gold Plated Packaging 135-9711-801 Stock 135-9711-802 Tape and Reel 1000 pcs/reel Recommended land pattern figure 2 on page 5 Mounting Hole Layout belfuse.com/cinch 5 NON-MAGNETIC RF CONNECTORS MCX Non-Magnetic RF Connectors ELECTRICAL SPECIFICATIONS Impedance: 50 Ohms Frequency Range 0-6 GHz VSWR: (f = GHz) Working Voltage (VRMS maximum) Straight Cable Connectors Right Angle Cable Connectors RG-178 cable RG-316 cable Uncabled Receptacles 1.17 + .09f 13 + .04f N/A 1.07 + .06f 1.07 + .04f N/A Connectors for Cable Type Sea Level 70K Feet 250 335 65 85 RG-178 RG-316 Dielectric Withstanding Voltage (VRMS minimum at sea level Connectors for RG-178, Uncabled Receptacles Connectors for RG-316, Uncabled Receptacles Insulation Resistance 750 1000 10,000 megohms minimum Contact Resistance (milliohms maximum) Center Contact (straight cabled connectors, uncabled receptacles) Center Contact (right angle cabled connectors) Outer Contact Braid to Body Initial After Environmental 5.0 5.0 1.0 1.0 8.0 15.0 1.5 N/A Corona Level (Volts minimum at 70,000 feet) Connectors for RG-178 Uncabled Receptacles Connectors for RG-316, Uncabled Receptacles 190 250 Insertion Loss (dB maximum, tested at 1 GHz) Straight Cable Connectors Right Angle Cable Connectors Uncabled Receptacles 0.1 0.2 N/A RF Leakage (dB minimum tested at 2.5 GHz) Cable connectors Uncabled receptacles RF High Potential Withstanding Voltage -55 N/A (VRMS minimum, tested at 4 and 7 MHz) Connectors for RG 178 Connectors for RG 316 Uncabled Receptacles MECHANICAL SPECIFICATIONS 500 700 600 Engagement Design Compatible with CECC 22220, Series MCX Engagement / Disengagement Force 5.6 pounds maximum axial force / 8 pounds maximum axial force, 1 pound min Contact Retention 2.3 pounds min. axial force (captivated contacts); 1 inch-ounce min. torque (uncabled receptacles) Cable Retention Connectors for RG178 Connectors for RG316 Connectors for RG316 DS *Or cable breaking strength whichever is less. Durability: Axial Force* (lbs) Torque (in-oz) 10 20 25 N/A N/A N/A 500 cycles minimum ENVIRONMENTAL SPECIFICATIONS (Meets or Exceeds the Applicable Paragraph of MIL-RF-39012) Temperature Range Thermal Shock Corrosion Shock Vibration Moisture Resistance 6 -65°C to +165°C MIL-STD-202, Method 107, Condition C (Except -55°C to 115°C) MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 213, Condition B MIL-STD-202, Method 204, Condition D MIL-STD-202, Method 106 NON-MAGNETIC RF CONNECTORS MCX Non-Magnetic RF Connectors Straight Crimp Type Plug - Solder or Crimp Contact - Captivated Contact Cable Type Gold Plated RG-178 133-9402-001 RG-316/U, 188, 174 133-9403-001 RG-316 DS, 188 DS 133-9404-001 See assembly instructions page 24 Straight Crimp Type Jack Receptacle Cable Type Gold Plated RG-316 133-9303-001 Right Angle Crimp Type Plug - Captivated Cable Type Gold Plated Silver Plated RG-316/U, 188, 174 133-9403-101 133-9403-104 RG-316 DS, 188 DS 133-9404-101 RG-178/U, 196 133-9402-101 See assembly instructions page 24 belfuse.com/cinch 7 NON-MAGNETIC RF CONNECTORS MCX Non-Magnetic RF Connectors For Flexible Cables Straight Jack Receptacle Gold Plated Silver Plated “A” 133-9701-201 133-9701-204 .155 (3.94) 133-9701-211 Mounting hole layout figure 4 on page 10 Straight Plug Receptacle, PCB Mount Gold Plated 133-9801-201 Straight Surface Mount, Jack Assembly Gold Plated 133-9711-201 8 .110 (2.79) NON-MAGNETIC RF CONNECTORS MCX Non-Magnetic RF Connectors For Flexible Cables Straight Jack Receptacle - .100" Layout Gold Plated 133-9701-231 Mounting hole layout figure 3 on page 10 Right Angle Jack Receptacle Gold Plated Silver Plated “A” 133-9701-301 133-9701-304 .155 (3.94) 133-9701-311 .110 (2.79) Mounting hole layout figure 4 on page 10 End Launch Jack Receptacle - Round Contact Gold Plated Board Thickness 133-9701-801 .062 (1.57) MCX Non-Magnetic RF Connectors For PC Mount Mounting Holes Layout belfuse.com/cinch 9 NON-MAGNETIC RF CONNECTORS SMA Non-Magnetic RF Connectors ELECTRICAL SPECIFICATIONS Impedance: 50 Ohms Frequency Range Flexible cable connectors Uncabled Receptacles VSWR: (f = GHz) Working Voltage (VRMS maximum) 0-12.4 GHz 0-18.0 GHz Straight Cable Connectors Right Angle Cable Connectors RG-316 RG-58 Uncabled Receptacles 1.15 + .02f 1.15 + .01f N/A 1.15 + .03f 1.15 + .02f N/A Connectors for Cable Type Sea Level 70K Feet 250 335 65 85 RG-316 RG-58, Uncabled Receptacles Dielectric Withstanding Voltage (VRMS minimum at sea leve)l Connectors for RG-316 Connectors for RG-58, Uncabled Receptacles Insulation Resistance 750 1000 5000 megohms minimum Contact Resistance (milliohms maximum) Center Contact (straight cabled connectors, uncabled receptacles) Center Contact (right angle cabled connectors) Outer Contact Braid to Body Initial After Environmental 3.0 4.0 2.0 0.5 4.0 6.0 N/A N/A Corona Level (Volts minimum at 70,000 feet) Connectors for RG-316 Connectors for RG-58, Uncabled Receptacles 190 250 Insertion Loss (dB maximum, tested at 1 GHz) Straight Cable Connectors Right Angle Cable Connectors Uncabled Receptacles 0.06 √f(GHz), tested at 6 GHz 0.15 √f(GHz), tested at 6 GHz N/A RF Leakage (dB minimum tested at 2.5 GHz) Cable connectors Uncabled Receptacles RF High Potential Withstanding Voltage -60 dB N/A (VRMS minimum, tested at 4 and 7 MHz) Connectors for RG-316 Connectors for RG-58,Uncabled receptacles 500 670 MECHANICAL SPECIFICATIONS Engagement Design MIL-STD-348, Series SMA Engagement / Disengagement Force 2 inch-pounds maximum Contact Retention 6 lb minimum axial force (captivated contacts); 4 inch-ounce minimum torque (uncabled receptacles) Mating Torque 7 to 10 inch-pounds Coupling Proof Torque 15 inch-pounds minimum Coupling Nut Retention 60 pounds minimum Cable Retention Durability: Connectors for RG-316 Connectors for RG-58 *Or cable breaking strength whichever is less. 500 cycles minimum Axial Force* (lbs) Torque (in-oz) 20 40 N/A N/A ENVIRONMENTAL SPECIFICATIONS (Meets or Exceeds the Applicable Paragraph of MIL-RF-39012) Temperature Range Thermal Shock Corrosion Shock Vibration Moisture Resistance 10 -65°C to +165°C MIL-STD-202, Method 107, Condition B MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 213, Condition I MIL-STD-202, Method 204, Condition D MIL-STD-202, Method 106 NON-MAGNETIC RF CONNECTORS SMA Non-Magnetic RF Connectors For Flexible and Semi-Rigid Cable Straight Solder Type Plug, Semi Rigid Cable Gold Plated 142-9003-201 Straight Crimp Type Plug (3-piece) - Captivated Contact Cable Type VSWR & Freq. Range Gold Plated RG-316/U, 188, 174 1.15 + .02f (GHz) 0-12.4 GHz 142-9403-011 RG-316 DS, 188 DS 1.15 + .02f (GHz) 0-12.4 GHz 142-9404-011 RG-58/U, 141 1.15 + .01f (GHz) 0-12.4 GHz 142-9407-001 See assembly instructions page 25 Right Angle Crimp Type Plug - Captivated Contact Cable Type VSWR & Freq. Range Gold Plated Silver Plated 142-9403-104 RG-316/U, 188, 174 1.15 + .03f (GHz) 0-12.4 GHz 142-9403-101 RG-316 DS, 188 DS 1.15 + .03f (GHz) 0-12.4 GHz 142-9404-101 RG-58/U, 141 1.15 + .02f (GHz) 0-12.4 GHz 142-9407-101 142-9407-104 See assembly instructions page 25 belfuse.com/cinch 11 NON-MAGNETIC RF CONNECTORS SMA Non-Magnetic RF Connectors For PC Mount Straight Crimp Type Blukhead Jack (3-piece) - Captivated Contact Cable Type VSWR & Freq. Range Gold Plated RG-316/U, 188, 174 1.15 + .02f (GHz) 0-12.4 GHz 142-9303-411 Frequency Range Gold Plated “A” 0-18 GHz 142-9701-201 .155 (3.94) 0-18 GHz 142-9701-211 .110 (2.79) See assembly instructions page 25 Mounting hole layout figure 5 on page 14 Straight Jack Receptacle Mounting hole layout figure 6 on page 14 Straight Plug Receptacle Frequency Range Gold Plated 0-18 GHz 142-9801-201 Mounting hole layout figure 6 on page 14 12 NON-MAGNETIC RF CONNECTORS SMA Non-Magnetic RF Connectors For PC Mount Right Angle Receptacle Frequency Range Gold Plated 0-18 GHz 142-9701-301 Mounting hole layout figure 6 on page 14 End Launch Receptacle - Round Contact Frequency Range Gold Plated Board Thickness 0-10 GHz 142-9701-801 .062 (1.57) Frequency Range Gold Plated Board Thickness 0-10 GHz 142-9701-811 .062 (1.57) End Launch Receptacle - Tab Contact Mounting hole layout belfuse.com/cinch 13 NON-MAGNETIC RF CONNECTORS SMB Non-Magnetic RF Connectors ELECTRICAL SPECIFICATIONS Impedance: 50 Ohms Frequency Range Connectors VSWR: (f = GHz) Working Voltage (VRMS maximum) 0 - 4 GHz Straight Cable Connectors Right Angle Cable Connectors RG-316 Uncabled Receptacles 1.25 + .04f N/A 1.35 + .04f N/A Connectors for Cable Type Sea Level 70K Feet 335 85 RG-316, Uncabled Receptacles Dielectric Withstanding Voltage (VRMS minimum at sea leve)l Connectors for RG-316, Uncabled Receptacles 1000 Insulation Resistance 1000 megohms minimum Contact Resistance (milliohms maximum) Center Contact (straight cabled connectors, uncabled receptacles) Center Contact (right angle cabled connectors) Outer Contact Braid to Body Initial After Environmental 6.0 12.0 1.0 .10 8.0 16.0 1.5 N/A Corona Level (Volts minimum at 70,000 feet) Connectors for RG-316 Uncabled Receptacles 250 N/A Insertion Loss (dB maximum, tested at 1.5 GHz) Straight Cable Connectors Right Angle Cable Connectors Uncabled Receptacles 0.3 dB 0.6 dB N/A Cable Connectors Uncabled Receptacles -55 dB N/A RF Leakage (dB minimum tested at 2.5 GHz) RF High Potential Withstanding Voltage (VRMS minimum, tested at 4 and 7 MHz) Connectors for RG-316 Uncabled Receptacles MECHANICAL SPECIFICATIONS 700 600 Engagement Design MIL-STD-348, Series SMB Engagement / Disengagement Force 2 pounds min to 14 pounds maximum axial force / 4 lb minimum axial force (captivated contacts) Contact Retention 4 lb minimum axial force (captivated contacts); 1 inch-ounce minimum torque (uncabled receptacles) Cable Retention Connectors for RG316 *Or cable breaking strength whichever is less. Durability: Axial Force* (lbs) Torque (in-oz) 20 N/A 500 cycles minimum ENVIRONMENTAL SPECIFICATIONS (Meets or Exceeds the Applicable Paragraph of MIL-RF-39012) Temperature Range Thermal Shock Corrosion Shock 14 -65°C to +165°C MIL-STD-202, Method 107, Condition B MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 213, Condition I NON-MAGNETIC RF CONNECTORS SMB Non-Magnetic RF Connectors For Flexible Cable Straight Crimp Type Plug - Solder or Crimp Captivated Contact Cable Type Gold Plated RG-316/U, 188, 174, 179, 187 131-9403-001 RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-001 See assembly instructions page 27 Straight Crimp Type Plug (3-piece), Solder or Crimp Captivated Contact Cable Type Gold Plated RG-316/U, 188, 174, 179, 187 131-9403-021 RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-021 See assembly instructions page 27 Right Angle Crimp Type Plug - Captivated Contact Cable Type Gold Plated RG-316/U, 188, 174, 179, 187 131-9403-101 RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-101 See assembly instructions page 27 belfuse.com/cinch 15 NON-MAGNETIC RF CONNECTORS SMB Non-Magnetic RF Connectors For Flexible Cable Straight Jack Receptacle Gold Plated “A” 131-9701-201 .155 (3.94) 131-9701-211 .095 (2.41) Mounting hole layout figure 7 on page 18 Straight Bulkhead Jack, Crimp Type, Flexible Cable Gold Plated 131-9303-401 Right Angle Jack Receptacle Gold Plated 131-9701-301 Mounting hole layout figure 7 on page 18 16 NON-MAGNETIC RF CONNECTORS SMB Non-Magnetic RF Connectors For Flexible Cable Mounting hole layout belfuse.com/cinch 17 NON-MAGNETIC RF CONNECTORS Type N Non-Magnetic RF Connectors ELECTRICAL SPECIFICATIONS Impedance: 50 Ohms Frequency Range Flexible Cabled and Receptacles 0-11 GHz VSWR: (f = GHz) 0-11 GHz Straight Flexible Cabled Uncabled Receptacles Working Voltage (VRMS maximum) 1.3 max N/A Connectors for Cable Type Sea Level 70K Feet RG-55/U RG-214, LMR-400 Cabled Uncabled Receptacles 335 1000 1000 85 250 250 Dielectric Withstanding Voltage (VRMS minimum at sea leve)l RG-55 RG-214, LMR-400 Cabled Uncabled Receptacles Insulation Resistance 1000 2500 2500 5000 megohms minimum Contact Resistance (milliohms maximum) Straight Cabled (non-captivated) Straight Cabled (captivated) Uncabled Receptacles Outer contact Braid to body Initial After Environmental 1.0 2.5 1.0 0.2 0.05 1.5 3.0 1.5 N/A N/A Corona Level (Volts minimum at 70,000 feet) RG-55 RG-214, LMR-400 Cabled Uncabled Receptacles 250 500 N/A Insertion Loss (dB maximum, tested at 9 GHz) Straight Cable Connectors Right Angle Cable Connectors Uncabled Receptacles 0.15 max 0.30 max N/A RF Leakage (dB minimum tested at 2.5 GHz) Cable connectors Uncabled receptacles RF High Potential Withstanding Voltage 90 N/A (VRMS minimum, tested at 4 and 7 MHz) RG-55 RG-214, LMR-400 Cabled Uncabled Receptacles 670 1500 1500 IMP3 Typically < -90 dBm (tested per IEC Guidelines using 20 W inputs swept over 1930-1990 MHz MECHANICAL SPECIFICATIONS Cabled Connectors Uncabled Receptacles Cable Retention (minimum*) Axial Force (lbs) 6 6 Torque (in-oz) N/A 4 Axial Force (lbs) Torque (in-oz) 45 90 N/A N/A RG-55 Cabled RG-214, LMR-400 Cabled *Or cable breaking strength whichever is less. ENVIRONMENTAL SPECIFICATIONS 18 Engagement Design MIL-STD-348A, Series N Bulkhead Mounting Nut Torque 15 inch-pounds recommended Engagement / Disengagement Force 6 inch-pounds maximum Coupling Proof Torque 15 inch-pounds minimum Durability 500 Cycles minimum Coupling Nut Retention 100 pounds minimum Mating Torque 7 to 10 inch-pounds Contact Retention minimum - captivated contacts only NON-MAGNETIC RF CONNECTORS Type N Non-Magnetic RF Connectors For Flexible Cable Straight Crimp Type Plug – Solder or Crimp Contact Cable Type VSWR & Freq. Range Tri-Alloy Plated Figure RG-55/U, 142, 223, 400 1.30 Max, 0-11 GHz 138-9408-007 A LMR-400, BELDEN 9913 1.30 Max, 0-11 GHz 138-9449-007 B See assembly instructions page 28 Right Angle Crimp Type Plug – Captivated Contact Cable Type VSWR & Freq. Range Tri-Alloy Plated “A” “B” RG-55/U, 142, 223, 400 1.35 Max, 0-9 GHz 1.50 Max, 9-11 GHz 138-9408-107 1.253 (31.83) 1.003 (25.48) RG-9/U, 214 1.35 Max, 0-9 GHz 1.50 Max, 9-11 GHz 138-9418-107 1.365 (34.67) 1.115 (28.32) See assembly instructions page 28 Straight Crimp Type Bulkhead Jack – Solder or Crimp Contact Cable Type VSWR & Freq. Range Tri-Alloy Plated “A” RG-55/U, 142, 223, 400 1.30 Max, 0-11 GHz 138-9308-407 .943 (23.95) LMR-400, BELDEN 9913 1.30 Max, 0-11 GHz 138-9349-407 .997 (25.32) See assembly instructions page 28 Mounting hole layout figure 8 on page 21 belfuse.com/cinch 19 NON-MAGNETIC RF CONNECTORS Type N Non-Magnetic RF Connectors For Bulkhead and Flange Mount Rear Mount Bulkhead Jack Receptacle Freq. Range Tri-Alloy Plated 0-11 GHz 138-9701-407 Mounting hole layout figure 8 on page 21 (below) 4-Hole Flange Mount Jack Receptacle – Flush Dielectric Freq. Range Tri-Alloy Plated 0-11 GHz 138-9701-607 Mounting hole layout figure 8 on page 21 (below) Mounting Hole Layout Asia Pacific +86 21 5442 7668 ccs.asia.sales@as.cinch.com Europe, Middle East & Africa +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com North America +1 507.833.8822 ccsorders@us.cinch.com belfuse.com/cinch © 2017 Cinch Connectivity Solutions CCS Johnson Non Magnetic Catalog rev 3 062017
135-9711-802 价格&库存
很抱歉,暂时无法提供与“135-9711-802”相匹配的价格&库存,您可以联系我们找货
