133-8801-201
133-8801-201
    CINCH
    MCX
133-8801-201 数据手册
MCX 75 Ohm Straight Plug Receptacle GOLD PLATED "A" “B” 133-8801-201 .155 (3.80) .343 (8.71) INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST Mounting hole layout Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com MCX - 75 Ohm Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedance: 75 Ohms Frequency Range: 0-6 GHz VSWR: (f = GHz) Power Rating: (Loads and matching pad only) 1.0 watt at +25°C derated linearly to 0.5 watt at +125°C Straight Cabled Right Angle Connectors Cabled Connectors RG-179 cable ............................... 1.13 + .04f 1.07 + .04f In-series adapters ........................ 1.07 + .03f Between series adapters, loads ... 1.05 + .01f Matching pad ............................... 1.05 + .05f Uncabled receptacles ..................................................................... N/A Working Voltage: (Vrms maximum)† Connectors for Cable Type Sea Level 70K Feet RG-179 ................................................... 335 85 Uncabled receptacles, adapters ............. 335 85 Loads, matching pad .............................. N/A Dielectric Withstanding Voltage: (VRMS minimum at sea level) Connectors for RG-179 ............................................................ 1000 Uncabled receptacles, adapters ............................................... 1000 Loads, matching pad .................................................................. N/A Corona Level: (Volts minimum at 70,000 feet)† Connectors for RG-179 .............................................................. 250 Uncabled receptacles, adapters ................................................. 250 Loads, matching pad .................................................................. N/A Insertion Loss: (dB maximum, tested at 1 GHz) Straight cable connectors ....................................................... 0.1 dB Right angle cable connectors ................................................. 0.2 dB Uncabled receptacles, adapters, matching pad ......................... N/A Insulation Resistance: 10,000 megohms minimum After Contact Resistance: (milliohms maximum) Initial Environmental Center contact (straight cabled connectors, uncabled receptacles) ....................................... 5.0 8.0 Center contact (right angle cabled connectors) .... 5.0 15.0 Center contact (loads, matching pads) ................ N/A Outer contact ........................................................ 1.0 1.5 Braid to body (gold plated connectors) ................. 1.0 N/A RF Leakage: (dB typical tested at 2.5 GHz) Cable connectors ....................................................... -55 dB typical Uncabled receptacles, adapters, loads, matching pads ............. N/A RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz)† Connectors for RG-179 .............................................................. 700 Uncabled receptacles, adapters ................................................. 600 Loads, matching pad .................................................................. N/A MECHANICAL RATINGS Engagement Design: Compatible with CECC 22220, Series MCX 50 Ohm Engagement Force: 5.6 pounds maximum axial force Disengagement Force: 8 pounds maximum axial force, 1 pound min. Contact Retention: 2.3 pounds min. axial force (captivated contacts) 1 inch-ounce min. torque (uncabled receptacles) Cable Retention: Axial Force* Torque (pounds) (in-oz) Connectors for RG-179 ............................... 20 N/A Connectors for RG179 DS .......................... 25 N/A *or cable breaking strength whichever is less ENVIRONMENTAL RATINGS (Meets or exceed the applicable paragraph of MIL-C-39012) Durability: 500 cycles minimum Temperature Range: All connectors: - 65°C to + 165°C Loads and matching pads: - 65°C to + 125°C Thermal Shock: MIL-STD-202, Method 107, Condition F Temperature Coefficient: Loads and matching pad: +/- 300ppm/ oC Corrosion: MIL-STD-202, Method 101, Condition B Shock: MIL-STD-202, Method 213, Condition B Vibration: MIL-STD-202, Method 204, Condition B Moisture Resistance: MIL-STD-202, Method 106 MATERIAL SPECIFICATIONS Bodies: Brass per QQ-B-626, gold plated** per MIL-G-45204 .00001” min. Interface spring - beryllium copper per QQ-C-530, gold plated per MIL-G-45204 .00003" min. Contacts: Male - brass per QQ-B-626 or beryllium copper per QQ-C530, gold plated per MIL-G-45204 .00003" min. Female - beryllium copper per QQ-C-530, gold plated per MIL-G45204 .00003" min. Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. Crimp Sleeves: Copper per WW-T-799, gold plated per MIL-G-45204 .00001" min. Mounting Hardware: Brass (nuts) per QQ-B-626 or phosphor bronze (lockwashers) QQ-B-750, gold plated per MIL-G-45204 .00001" min. †Avoid user injury due to misapplication. See safety advisory definitions inside front cover. ** All gold plated parts include a .00005" min. nickel underplate barrier layer. MATING ENGAGEMENT FOR 75 OHM MCX SERIES (INTERMATABLE WITH CECC 22220 50 OHM MCX) JACK JACK PLUG PLUG NOTES 1. ID of contact to meet VSWR mating characteristics and connector durability when mated with a dia. .019-.021 (0.48-0.53) male contact. 2. Must meet the force to engage and disengage when mated with mating part. 3. Interface shall intermate with MCX 50 Ohm interface per CECC 22220. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
133-8801-201 价格&库存
很抱歉,暂时无法提供与“133-8801-201”相匹配的价格&库存,您可以联系我们找货
  • 250+62.05791250+8.03867
