131-6701-211
131-6701-211
    CINCH
    插件
    SMC
131-6701-211 数据手册
50 Ohm SMC Straight Jack PC Mount Receptacle "A" .110 (2.79) GOLD PLATED NICKEL PLATED 131-6701-211 131-6701-216 INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST IR COMPATIBLE* 131-6701-215* *Tin/Lead Solder dipped legs for IR Reflow Compatibility. Mounting hole layout Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com SMC - 50 Ohm Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedence: 50 ohms Frequency Range: 0-10 GHz VSWR: (f = GHz) Straight Cabled RG-178 cable ................................... 1.25 + .04f RG-316 and .086 semi-rigid cable ............................................. 1.20 + .04f Uncabled receptacles ............................ N/A Adapters ........................................... 1.20 + .04f Right Angle Cabled 1.40 + .06f 1.30 + .04f Working Voltage: (Vrms maximum)† Connectors for Cable Type Sea Level 70K Feet RG-178 ............................................... 250 60 RG-316, .086 semi-rigid uncabled receptacles, adapters ........ 335 85 Dielectric Withstanding Voltage: (VRMS minimum at sea level)† Connectors for RG-178 ........................................................................... 750 Connectors for RG-316, .086 semi-rigid uncabled receptacles, adapters ........................................................... 1000 Corona Level: (Volts minimum at 70,000 feet)† Connectors for RG-178 ........................................................................... 185 Connectors for RG-316, .086 semi-rigid .................................................. 250 Uncabled receptacles and adapters ........................................................ N/A Insertion Loss: (dB maximum, tested at 4 GHz) Straight cable connectors .................................................................. 0.25 dB Right angle cable connectors ............................................................ 0.50 dB Uncabled receptacles and adapters ........................................................ N/A Insulation Resistance: 1000 megohms minimum Contact Resistance: (milliohms maximum) After Initial Environmental Center contact (straight cabled connectors and uncabled receptacles) .............. 6.0 8.0 Center contact (right angle cabled connectors and adapters) ................................ 12.0 16.0 Outer contact (gold plated connectors) ................. 1.0 N/A Outer contact (nickel plated connectors) .............. 2.5 N/A Braid to body (gold plated connectors) ................. 1.0 N/A Braid to body (nickel plated connectors) ............... 2.5 N/A RF Leakage: (dB minimum tested at 2.5 GHz) Cable connectors ............................................................................... -55 dB Uncabled receptacles and adapters ........................................................ N/A ** All gold plated parts inlcude a .00005" min. nickel underplate barrier layer. RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz)† Connectors for RG-178 ........................................................................... 500 Connectors for RG-316 ........................................................................... 700 Uncabled receptacles and adapters ........................................................ 600 MECHANICAL RATINGS Engagement Design: MIL-C-39012, Series SMC Engagement/Disengagment Force: 16 inch-ounce maximum torque Mating Torque: 35 to 50 inch-ounce Coupling Proof Torque: 100 inch-ounce minimum Coupling Nut Retention: 35 pounds minimum Contact Retention: 4 lbs. minimum axial force (captivated contacts) 1 inch-ounce minimum torque (uncabled receptacles) Cable Retention: Axial Force* Torque (pounds) (in-oz) Connectors for RG-178 ...................................... 10 N/A Connectors for RG-316 ...................................... 20 N/A Connectors for .086 semi-rigid ........................... 30 16 * or cable breaking strength whichever is less Durability: 500 cycles minimum ENVIRONMENTAL RATINGS (Meets or exceed the applicable paragraph of MIL-C-39012 Temperature Range: - 65° C to + 165° C Thermal Shock: MIL-STD-202, Method 107, Condition B Corrosion: MIL-STD-202, Method 101, Condition B Shock: MIL-STD-210, Method 213, Condition C Vibration: MIL-STD-202, Method 204, Condition D MATERIAL SPECIFICATIONS Bodies: Brass per QQ-B-626, gold plated** per MIL-G-45204 .00001" min or nickel plated per QQ-N-290 Contacts: Male - brass per QQ-B-626, gold plated per MIL-G-45204 .00003" min. Female - beryllium copper per QQ-C-530, gold plated per MIL-G-45204 .00003" min. Nut Retention Spring: Beryllium copper per QQ-C-533, unplated Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Crimp Sleeves: Copper per WW-T-799, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Mounting Hardware: Brass (nuts) per QQ-B-626 or phosphor bronze (lockwashers) per QQ-B-750, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Avoid user injury due to misapplication. See safety advisory definitions inside front cover. MATING ENGAGEMENT FOR SMC SERIES PER MIL-C-39012 PLUG PLUG JACK JACK NOTES 1. Inside of contact to meet VSWR, mating characteristics and connector durability when mated with a dia .019/.021 (0.48/0.53) male contact. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
131-6701-211 价格&库存
很抱歉,暂时无法提供与“131-6701-211”相匹配的价格&库存,您可以联系我们找货
  • 250+58.19043250+7.56457
