HDBNC-J-P-GN-ST-EM1
HDBNC-J-P-GN-ST-EM1
    SAMTEC(申泰)
    BNC
HDBNC-J-P-GN-ST-EM1 数据手册
REVISION E DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] HDBNC-J-P-XX-ST-EM1 TERMINATION -EM1: EDGE MOUNT .062 BOARD GENDER -J: JACK DO NOT SCALE FROM THIS PRINT ORIENTATION -ST: STRAIGHT TYPE -P: PCB PLATING SPECIFICATION -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -HN: 30µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -GN: 10µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT (SEE TABLE 1) 6.25 .246 REF 5.63 .221 REF (ON FLAT) 4.55 .179 REF RECOMMENDED MOUNTING HOLE 2.70 [.079] MAX PANEL THICKNESS 0.43 .017 REF "A" 6.50 .256 5.51 .217 REF 0.76 .030 REF (TO INSULATOR) 6.50 .256 REF 11.25 .443 REF 14.91 .587 REF (TO SOCKET) 12.75 .502 REF 2 (SEE NOTE 4) 5.90 .232 RECOMMENDED PCB LAYOUT 17.50 .689 REF (SEE NOTE 5 & 6) 1/4-36 UNS-2A REF 7.58 .298 1.91 .075 (2 PLCS) 4.75 .187 REF 1 "A" 1.80 .071 (2 PLCS) REF 4.90 .193 (2 PLCS) 0.30 .012 (2 PLCS) REF 7.50 .295 REF NOTES: 0.60 .024 REF SECTION "A"-"A" UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: 1. C REPRESENTS A CRITICAL DIMENSION. 2. NOTE DELETED. 3. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-RF-WI-3040-M. TRAY: TY-SMA-001-1 COVER: TY-SMA-001-2 4. NUT TO BE PACKAGED SEPARATELY. 4.50 .177 REF 5. STENCIL APERTURES TO BE 1:1 WITH THE PCB SURFACE MOUNT PADS. STENCIL THICKNESS TO BE 0.13 [.005]. 6. A FIXTURE IS RECOMMENDED DURING THE REFLOW PROCESS TO HOLD THE CONNECTOR STRAIGHT AND PARALLEL WITH THE PCB. CONTACT IPG FOR MORE DETAILS. F:\DWG\MISC\MKTG\HDBNC-J-P-XX-ST-EM1 -MKT.SLDDRW 2.30 .091 DECIMALS * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND 0.70 .028 * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: EDGE OF PCB AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SOCKET: BeCu SHELL, NUT: BRASS INSULATOR: PTFE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY SHEET SCALE: 4:1 DESCRIPTION: HD BNC 75 OHM, ST JACK EDGE MOUNT DWG. NO. HDBNC-J-P-XX-ST-EM1 BY: ALVIN W 02/11/2011 SHEET 1 OF 1
HDBNC-J-P-GN-ST-EM1 价格&库存
很抱歉,暂时无法提供与“HDBNC-J-P-GN-ST-EM1”相匹配的价格&库存,您可以联系我们找货
HDBNC-J-P-GN-ST-EM1
    • 1+53.33040
    • 10+52.15320
    • 30+51.37560
    库存:1
