131-8434-001
131-8434-001
    CINCH
    SMB
131-8434-001 数据手册
SMB 3-Piece Straight Plugs 1. Identify connector parts. (3 piece parts): Crimp sleeve, body assembly and contact 2. Strip cable to dimensions shown. Do not nick braid or center conductor. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. Slide heat shrink (as applicable) and crimp sleeve onto jacket of cable. 3. Assemble contact onto cable as shown. Solder Attachment: Solder contact to center conductor through solder hole using .015 (0.38) diameter solder. Use a minimum amount of solder for a good joint. Crimp Attachment: A miniature 8 indent crimp tool 140-0000970 is recommended. Crimp location should be centered between end of contact and X-hole using positioner 1400000-971. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide body assembly over contact and under braid. Then seat body assembly firmly onto contact. The cable may have to be held in a clamping fixture. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using recommended crimp tool. Slide heat shrink forward and shrink (as applicable). Cable Group Part No. Crimp Hex RG-316/U, 161, 174, 179, 187, 188 131-3403-021/026 .128 (3.25) RG-316 DS, 188 DS, 179 DS 131-3404-021/026 .151 (3.83) RG-58/U, 141, 303 131-3407-011/016 .213 (5.41) RG-179/U, 187 131-8433-001/006 .128 (3.25) RG-179 DS, 187 DS 131-8434-001/006 .151 (3.83) Belden 735A 131-8445-011/016 .178 (4.52) RG-316/U, 188, 174, 179, 187 131-9403-021 .128 (3.25) RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-021 .151 (3.83) 252 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-8434-001 价格&库存
很抱歉,暂时无法提供与“131-8434-001”相匹配的价格&库存,您可以联系我们找货
