131-8404-116
131-8404-116
    CINCH
    SMB PLG RA MINI-75OHM RG179DS
131-8404-116 数据手册
SMB/SMC/Mini-75Ohm SMB Crimp Type Right Angle Plugs and Right Angle Bulkhead Jacks for Flexible Cable 1. Identify connector parts. (4 piece parts: crimp sleeve, body assembly, expansion cap and covering ring. Die cast body only.) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body assembly making certain that the cable insulation bottoms on center contact. Arrange braid uniformly around crimp stem of body assembly. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. 4. Solder center conductor to contact through the rear and side access ports. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. Place expansion cap in access port and seat with a .125 (3.17) diameter flat punch. Snap cover ring over side access port if applicable. Cable Group Part No. “A” “B” Crimp Hex RG-178/U, 196 131-1402-101/116 .219 (5.56) .312 (7.92) .105 (2.67) RG-316/U, 161, 174, 179, 187, 188 131-1403-101/116 .219 (5.56) .312 (7.92) .128 (3.25) RG-179 DS, 187 DS,188DS, 316 DS 131-1404-101/116 .219 (5.56) .312 (7.92) .151 (3.83) RG-316/U, 161, 174,179, 187, 188 131-3303-501/506 .219 (5.56) .312 (7.92) .128 (3.25) RG-179 DS, 187 DS,188 DS, 316 DS 131-3304-501/506 .219 (5.56) .312 (7.92) .151 (3.83) RG-178/U, 196 131-3402-101/116 .177 (4.50) .289 (7.34) .105 (2.67) RG-316/U, 161, 174,179, 187, 188 131-3403-101/116 .177 (4.50) .289 (7.34) .128 (3.25) RG-179 DS, 187 DS,188 DS, 316 DS 131-3404-101/116 .177 (4.50) .289 (7.34) .151 (3.83) RG-58/U, 141, 303 131-3407-101/106 .219 (5.56) .289 (7.34) .213 (5.41) RG-316/U, 161, 174, 188 131-6403-101/106 .219 (5.56) .312 (7.92) .128 (3.25) 316 DS, 188 DS 131-6404-101/106 .219 (5.56) .312 (7.92) .151 (3.83) RG-179/U, 187 131-6433-101/106 .219 (5.56) .312 (7.92) .151 (3.83) RG-179/U, 187, 316, 131-8403-101/106 .177 (4.50) .289 (7.34) .128 (3.25) 161, 174, 188 131-8403-111/116 .219 (5.56) .312 (7.92) .128 (3.25) RG-179 DS, 187 DS 131-8404-101/106 .177 (4.50) .289 (7.34) .151 (3.83) 316 DS, 188 DS 131-8404-111/116 .219 (5.56) .312 (7.92) .151 (3.83) RG-59 131-8409-101/106 .219 (5.56) .289 (7.34) .255 (6.48) BELDEN 735A 131-8445-101/106 .177 (4.50) .289 (7.34) .178 (4.52) RG-316/U, 188, 174, 179, 187 131-9403-101/116 .177 (4.50) .289 (7.34) .128 (3.25) RG-316 DS, 188 DS, 179 DS, 187 DS 131-9404-101/116 .177 (4.50) 2.89 (7.34) .151 (3.83) 258 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-8404-116
1. 物料型号:文档列出了不同型号的连接器,例如CRMP SIVE CRIMPSIEVE END CAP CONNECTOR BOOY和SMBBUUOHEADJACK,以及它们对应的部件编号。
2. 器件简介:介绍了连接器的组成部件,包括压接套筒、本体组件、扩张帽和覆盖环,以及压接工具的使用。
3. 引脚分配:文档中没有明确提到引脚分配,但提供了连接器的组装说明。
4. 参数特性:提供了不同电缆组的部件编号和对应的参数,如"A"、"B"、Crimp Hex的尺寸。
5. 功能详解:详细描述了如何剥去电缆、压接、焊接中心导体以及如何安装扩张帽和覆盖环。
6. 应用信息:文档中没有直接提到应用信息,但可以推断这些连接器适用于需要灵活电缆连接的场合。
7. 封装信息:提供了连接器的封装类型和尺寸信息。
131-8404-116 价格&库存
很抱歉,暂时无法提供与“131-8404-116”相匹配的价格&库存,您可以联系我们找货
  • 250+62.01766250+8.03867
