SMB7H-P-C-H-ST-CA3
SMB7H-P-C-H-ST-CA3
    SAMTEC(申泰)
    SMB
SMB7H-P-C-H-ST-CA3 数据手册
REVISION G PRODUCT MANUFACTURED Pb THIS WITH LEAD-FREE PROCESSING DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] SMB7H-P-C-XX-ST-CA3 DO NOT SCALE FROM THIS PRINT GENDER -P: PLUG TERMINATION -CA3: RG179 CABLE TYPE -C: CABLE ORIENTATION -ST: STRAIGHT PLATING -HN: 30µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT -H: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT (SEE TABLE 1) 1 2 2.70 .106 REF 3 0.92 .036 REF 6.35 .250 REF 3.90 .154 REF 11.10 .437 REF 7.82 .308 REF 7.00 .276 REF 16.60 .654 REF F:\DWG\MISC\MKTG\SMB7H-P-C-XX-ST-CA3-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS [INCHES] NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. PUSHOUT FORCE FOR CENTER CONTACT: 17.79 N [4.0 LB] MIN. 3. NOTE DELETED. 4. NOTE DELETED. 5. PRODUCT TO BE PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. 6. NOTE DELETED. 7. NOTE DELETED. 8. NOTE DELETED. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 5 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL, FERRULE: BRASS CONTACT: COPPER ALLOY DIELECTRIC: PTFE SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: SMB STRAIGHT CABLE PLUG, RG179 - 75 OHM DWG. NO. SMB7H-P-C-XX-ST-CA3 BY: G. HERMAN 10/09/2008 SHEET 1 OF 2 C 2.00±0.30 .079±.012 REVISION G RG179 CABLE IN PROCESS 1 STRIP AND TIN INNER CONDUCTOR C 4.20±0.30 .165±.012 9.50±0.30 .374±.012 C 3 HST-0.125-02-BLK IN PROCESS 2 ADD HEAT SHRINK TUBE AND FERRULE 20.0±2.5 .79±.10 2.70 .106 (MIN. FLAIRED ID) IN PROCESS 3 FLARE SHIELD 2 0.10 .004 MAX GAP ALLOWABLE C IN PROCESS 4 SOLDER SIGNAL SOCKET 1.49 .058 REF (TO CENTER CONTACT) 'A' 1 IN PROCESS 5 ADD SUB ASSEMBLY DETAIL 'A' SCALE 4 : 1 0.25 .010 MAX GAP ALLOWABLE C IN PROCESS 6 CRIMP FERRULE (USE RF CRIMP HAND TOOL #CAT-HT-126667-21 OR EQUIVALENT) 3.25 .128 HEX CRIMP C (ACROSS 2 FACES) F:\DWG\MISC\MKTG\SMB7H-P-C-XX-ST-CA3-MKT.SLDDRW PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. 0.6 .03 MAX GAP ALLOWABLE IN PROCESS 7 APPLY HEAT SHRINK TUBE DO NOT SCALE DRAWING SHEET SCALE: 1:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: SMB STRAIGHT CABLE PLUG, RG179 - 75 OHM DWG. NO. SMB7H-P-C-XX-ST-CA3 BY: G. HERMAN 10/09/2008 SHEET 2 OF 2
SMB7H-P-C-H-ST-CA3 价格&库存
很抱歉,暂时无法提供与“SMB7H-P-C-H-ST-CA3”相匹配的价格&库存,您可以联系我们找货
SMB7H-P-C-H-ST-CA3
  • 1+62.229451+8.08963
库存:8
