GRF1-J-P-02-E-ST-TH1
    SAMTEC(申泰)
    插件
GRF1-J-P-02-E-ST-TH1 数据手册
REVISION B GRF1-J-P-XX-X-XX-XXX-X DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] DO NOT SCALE FROM THIS PRINT C1 GENDER -J: JACK PCB -P: PCB MOUNT (No OF POS x 5.00[.197] REF (No OF POS -1) x 5.00[.197] 5.00 .197 REF (TYP) INSERT OPTIONS -E: #1-64 THRU HOLE THREADED INSERT (SEE FIG. 2, SHT 2) TERMINATION -TH1: THRU HOLE No OF POSITIONS -02, -04, -06, -08 C2 "A" ORIENTATION -ST: STRAIGHT PLATING -E: 50u" GOLD ON CENTER CONDUCTOR CONTACT AREA AND SOLDER TAIL. 3u" GOLD ON SHELL AND SHELL SOLDER TAILS 5.00 .197 REF 3.50 .138 REF (TYP) "A" SUB-GRF1-J-P-X-XX-XXX C3 2.80±0.10 .110±.004 GRF1-XX-XX-XXX-X 2.00 .079 REF 1.80 .071 REF 4.60 .181 REF 2.80 .11 REF 0.50 .020 SQ REF (TYP) 0.70 .028 REF (TYP) ((No OF POS -1) x 5.00[.197]) + 2.54[.100] 2.54 .100 REF (TYP) 5.00 .197 REF (TYP) (No OF POS -1) x 5.00[.197] 1. C REPRESENTS A CRITICAL DIMENSION. 2. MINIMUM PUSHOUT FORCE: 2.22N [.5 LB]. GRF1-J-P-04-E-ST-TH1 SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: X.X: 0.3 X.XX: 0.13 X.XXX: 0.050 MATERIAL: ANGLES 2 B PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: L.C.P. COLOR: BLACK SHELL: BRASS PIN: BeCu INSULATOR: TEFLON F:\DWG\MISC\Mktg\GRF1-J-P-XX-X-XX-XXX-X-MKT.SLDDRW PACKAGING VIEW USE: PT 1-24-04-36-TP-09 FIG. 1 2.54 .100 REF (TYP) DECIMALS NOTES: SECTION "A"-"A" SCALE 6 : 1 SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: GANGED RF JACK CONNECTOR DWG. NO. GRF1-J-P-XX-X-XX-XXX-X BY: CHAD F 9/3/2004 SHEET 1 OF 2 REVISION B No OF POS x 5.00[.197] + 12.20[.480] REF No OF POS x 5.00[.197] + 7.20[.283] C4 "A" #1-64 UNC-2B "A" 3.50 .14 REF (2 PLCS) WT-21-01 2.45±0.10 .096±.004 2.80±0.25 .110±.010 C5 C6 (No OF POS x 5.00[.197]) + 9.74[.383] 2.54 .100 REF (TYP) FIG. 2 GRF1-J-P-04-E-ST-TH1-E SHOWN (SAME AS FIG.1, UNLESS OTHERWISE STATED) PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\Mktg\GRF1-J-P-XX-X-XX-XXX-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: GANGED RF JACK CONNECTOR DWG. NO. GRF1-J-P-XX-X-XX-XXX-X BY: CHAD F 9/3/2004 SHEET 2 OF 2
GRF1-J-P-02-E-ST-TH1 价格&库存
很抱歉,暂时无法提供与“GRF1-J-P-02-E-ST-TH1”相匹配的价格&库存,您可以联系我们找货
    • 1+71.18280
    • 174+28.40400
    • 522+27.45360
    • 986+26.98920
