146-0403-007
146-0403-007
    CINCH
    CONN QMA PLUG STR 50 OHM CRIMP
146-0403-007 数据手册
kwiQMAte™ Straight Plugs for Flexible Cable – Crimp or Solder Contacts 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. Slide heat shrink (as applicable) and crimp sleeve onto jacket of cable. 3. Assemble contact onto cable as shown. Solder Attachment: Solder contact to center conductor through solder hole using .020 (0.51) diameter solder. Use a minimum amount of solder for a good joint. Crimp Attachment: Crimp contact to center conductor using Johnson® Hand Tool 144-0000910, setting #2. Crimp location should be centered between end of contact and X-hole. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide body assembly over contact and under braid. Then seat body assembly firmly onto contact. The cable may have to be held in a clamping fixture. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using recommended crimp tool. Slide heat shrink forward and shrink (as applicable). Cable Group Part No. Crimp Hex RG-316 146-0403-007 .128 (3.25) RG-316 DS 146-0404-007 .151 (3.83) 276 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
146-0403-007 价格&库存
很抱歉,暂时无法提供与“146-0403-007”相匹配的价格&库存,您可以联系我们找货
