REVISION P
BNC7T-P-C-XX-ST-CA3XX
DESIGNED & DIMENSIONED
IN MILLIMETERS[INCHES]
CRIMP OPTION
(LEAVE BLANK FOR SOLDERED CENTER CONTACT)
-C: CRIMPABLE CENTER CONTACT
(USE BNC7T-P-C-X-ST-CA3-PIN-C)
GENDER
-P: PLUG
DO NOT
SCALE FROM
THIS PRINT
TYPE
-C: CABLE
MANUFACTURING OPTION
(LEAVE BLANK FOR MACHINED)
-D: DIE CAST
PLATING SPECIFICATION
-GN: 10µ" GOLD CENTER CONTACT,
100µ" NICKEL OUTER CONTACT
(SEE TABLE 1)
TERMINATION
-CA3: CABLE(RG179)
ORIENTATION
-ST: STRAIGHT
"B" REF
"A" REF
9.50 .374
REF
12.65 .498
REF
14.50 .571
REF
3.90 .154 REF
2
1
2.70 .106 REF
1.35 .053 REF
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN
MILLIMETERS [INCHES].
TOLERANCES ARE:
DECIMALS
ANGLES
.X: 0.3 [.01]
5
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
NOTES:
1. NOTE DELETED.
2. NOTE DELETED.
3. PRODUCT TO BE BULK PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M.
4. NOTE DELETED.
F:\DWG\MISC\MKTG\BNC7T-P-C-XX-ST-CA3XX-MKT.SLDDRW
3
1.57 .062 REF
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
COUPLING NUT:
-CA3X OPTION: BRASS, -CA3DX OPTION: ZAMAK 3
CABLE BODY, FERRULE, CONTACT: BRASS
GASKET: SILICONE
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
TRUE 75 OHM, BNC STRAIGHT PLUG, RG179
DWG. NO.
BY: G.HERMAN
06/19/2008
SHEET 1 OF 2
REVISION P
RG179 CABLE
3.2 .13
5.4 .21
12.1 .48
IN-PROCESS 1
STRIP CABLE AND TIN INNER CONDUCTOR
PIN SHOULD BE FLUSH TO CABLE INSULATOR
3
2
HEAT SHRINK
20.00 .79
IN-PROCESS 2
ADD HEAT SHRINK TUBING AND FERRULE,
SOLDER SIGNAL PIN (CA3 & CA3D OPTIONS), OR CRIMP
(USE DANIELS WA22CJ TOOL AND K1764 POSITIONER,
CRIMP ON SETTING 7) (CA3C & CA3DC OPTIONS)
1
IN-PROCESS 3
FLARE SHIELD & ADD SUB ASSEMBLY
FERRULE SHOULD BE FLUSH TO SUB ASSEMBLY
IN-PROCESS 4
CRIMP FERRULE
(USE RF CRIMP HAND TOOL #CAT-RF-FER-01,
AND .128" DIE SIZE)
HEAT SHRINK SHOULD BE FLUSH TO SUB ASSEMBLY
PROPRIETARY NOTE
IN-PROCESS 5
ACTIVATE HEAT HEAT SHRINK
SHEET SCALE: 1.25:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: G.HERMAN
06/19/2008
SHEET 2 OF 2
BNC7T-P-C-GN-ST-CA3 价格&库存
很抱歉,暂时无法提供与“BNC7T-P-C-GN-ST-CA3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+69.545271+9.03919
- 25+60.2798225+7.83491
- 50+50.9706650+6.62495
- 100+42.24057100+5.49025
