HDBNC-J-P-GN-ST-BH1
HDBNC-J-P-GN-ST-BH1
    SAMTEC(申泰)
    插件
HDBNC-J-P-GN-ST-BH1 数据手册
REVISION B HDBNC-J-P-XX-ST-BH1 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] TERMINATION -BH: BULKHEAD THROUGH HOLE GENDER -J: JACK DO NOT SCALE FROM THIS PRINT ORIENTATION -ST: STRAIGHT TYPE -P: PCB PLATING SPECIFICATION -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -HN: 30µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -GN: 10µ" GOLD CENTER CONTACT, 100µ" NICKEL OUTER CONTACT (SEE TABLE 1) 5.63 .221 REF (ON FLAT) 4.55 .179 REF RECOMMENDED MOUNTING HOLE "A" 2.20 [.079] MAX PANEL THICKNESS 0.76 .030 REF (TO INSULATOR) 0.43 .017 REF 6.50 .256 5.51 .217 REF 6.50 .256 REF 13.25 .522 REF 5.90 .232 10.74 .423 REF 1/4-36 UNS-2A REF 16.96 .668 REF (TO SOCKET) 2 (SEE NOTE 4) RECOMMENDED PCB LAYOUT 1 1.70 .067 PTH 3.70 .146 REF 0.76 .030 PTH "A" 0.51 .020 REF 0.92 .036 (4 PLCS) REF 2.54 .100 (4 PLCS) SECTION "A"-"A" 5.08 .200 (4 PLCS) 6.00 .236 REF 5.08 .200 (4 PLCS) REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. NOTE DELETED. 3. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-RF-WI-3040-M. TRAY: TY-SMA001-1 COVER: TY-SMA001-2 4. NUT TO BE PACKAGED SEPARATELY. ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] 1.50 .059 (8 PLCS) REF F:\DWG\MISC\MKTG\HDBNC-J-P-XX-ST-BH1-MKT.SLDDRW MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SOCKET: BeCu SHELL, NUT: BRASS INSULATOR: PTFE SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HD BNC 75 OHM, ST JACK BULKHEAD DWG. NO. HDBNC-J-P-XX-ST-BH1 BY: ALVIN W 02/11/2011 SHEET 1 OF 1
HDBNC-J-P-GN-ST-BH1
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
HDBNC-J-P-GN-ST-BH1 价格&库存
很抱歉,暂时无法提供与“HDBNC-J-P-GN-ST-BH1”相匹配的价格&库存,您可以联系我们找货
HDBNC-J-P-GN-ST-BH1
    • 1+59.15160
    • 10+51.67800
    • 30+47.12040
    • 100+36.80262
    库存:67
    HDBNC-J-P-GN-ST-BH1
    • 1+67.302621+8.71805
    • 25+58.3201225+7.55450
    • 50+49.4116450+6.40054
    • 100+35.91656100+4.65245
    • 500+32.11515500+4.16004
    • 1000+31.643071000+4.09889
    库存:723
