MCX Crimp Type Straight Connectors for Flexible Cable
1. Identify connector parts. (3 piece parts – except bulkhead)
2. Strip cable to dimensions shown. Do not nick braid or
center conductor. Tin center conductor if contact is to be
solder attached. Do not tin center conductor if contact is
to be crimp attached. Slide heat shrink (as applicable) and
crimp sleeve onto jacket of cable.
3. Assemble contact onto cable as shown. Solder attachment.
Solder contact to center conductor through solder hole
using .020 (0.51) diameter solder. Use a minimum of solder
for a good joint. Crimp attachment. Crimp contact to
center conductor using a miniature 8 indent tool 1400000-970 with positioner 140-0000-971. Crimp location
should be centered between end of contact and cross hole.
Crimp attachment to solid center conductor cable is not
recommended.
4. Flair braid and slide body assembly over contact and
under braid. Then seat body assembly firmly onto contact.
(RG-178 is non-captivated, RG-316 incorporates snap-fit
captivation.) The cable may have to be held in a clamping
fixture. Arrange braid uniformly around crimp stem. Slide
crimp sleeve forward and crimp using recommended crimp
tool. Slide heat shrink forward and shrink (as applicable).
Cable Group
Part No.
Crimp Hex
RG-178/U, 196
133-3302-001/006
133-3302-401/406
.105 (2.67)
.105 (2.67)
RG-316/U, 161, 174, 188
133-3303-001/006
133-3303-401/406
.128 (3.25)
.128 (3.25)
RG-316 DS, 188 DS
133-3304-001/006
133-3304-401/406
.151 (3.83)
.151 (3.83)
RG-178/U, 196
133-3402-001/006
.105 (2.67)
133-3403-001/006
.128 (3.25)
RG-316 DS, 188 DS
133-3404-001/006
.151 (3.83)
RG-179/U, 187
133-3433-001/006
.128 (3.25)
RG-178/U, 196
133-5302-401/406
.105 (2.67)
133-5303-401/406
.128 (3.25)
RG-316 DS, 188 DS
133-5304-401/406
.151 (3.83)
RG-178/U, 196
133-5402-001/006
.105 (2.67)
133-5403-001/006
.128 (3.25)
RG-316 DS, 188 DS
133-5404-001/006
.151 (3.83)
RG-316/U, 188, 174
133-9403-001
.128 (3.25)
RG-316 DS, 188 DS
133-9404-001
.151 (3.83)
227
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“133-5403-001”相匹配的价格&库存,您可以联系我们找货
