SMA 3-Piece Plug, Jack and Bulkhead Jack for RG-178 Flexible Cable
1. Identify piece parts. (4 piece parts plus nut and washer for bulkhead.)
2. Strip cable jacket and braid to dimensions shown. Do not nick braid
during strip operations.
3. Slide crimp insert over braid and against jacket. Fold braid around
crimp insert as shown. Strip dielectric to dimension shown. If cable is
being manually stripped the rear insulator can be assembled and used
as a guide. Do not nick center conductor during strip operation. Tin
center conductor if contact is to be solder attached. Do not tin center
conductor if contact is to be crimp attached.
4. Assemble rear insulator over cable dielectric and contact over center
conductor as shown. Solder attachment: Solder contact to center
conductor using 60/40 tin/lead solder. Care should be taken that
excess solder is not applied. Crimp attachment: Crimp contact to
center conductor using production tooling or hand tool 144-0000-910,
setting #2 with positioner 141-0000-907. Crimp location should be
centered between end of contact and x-hole. Crimp attachment to
solid center conductor cables is not recommended.
5. Slide body assembly over contact, rear insulator and crimp insert.
Crimp body using recommended crimp tool. Maintain forward
pressure on cable while crimping. Body crimp die hex: .105 (2.67) hex.
Cable Group
Part No.
Crimp Hex
RG-178/U, 196
142-0402-011
142-0402-016
142-0302-011
142-0302-016
142-0302-431
142-0302-436
.105 (2.67)
.105 (2.67)
.105 (2.67)
.105 (2.67)
.105 (2.67)
.105 (2.67)
237
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“142-0402-016”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+68.08267250+8.83367
