131-3593-406
131-3593-406
    CINCH
    SMB
131-3593-406 数据手册
SMB/SMC Solder Type Straight Plugs and Jacks for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts – except bulkhead) 2. Strip cable to dimensions shown. Do not nick center conductor. Slide cover sleeve onto cable as shown. 3. Insert cable into body making certain that the cable insulation bottoms on center contact. Solder center conductor to contact through the side access ports and hole in center contact. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. 4. Slide cover sleeve over access ports and solder body to cable and cover sleeve to body. Use a minimum amount of heat to minimize cable insulation movement. Cable Group Part No. “A” RG-405/U(.086 Semi-Rigid) 131-3593-401/406 131-3693-001/016 .025 (0.64) .025 (0.64) RG-402/U (.141 Semi-Rigid) 131-3694-401/406 .050 (1.27) RG-405/U (.086 Semi-Rigid) 131-6593-401/406 .025 (0.64) 253 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
131-3593-406 价格&库存
很抱歉,暂时无法提供与“131-3593-406”相匹配的价格&库存,您可以联系我们找货
