142-0693-106
142-0693-106
    CINCH
    SMA
142-0693-106 数据手册
SMA Right Angle Solder Type Plug for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor during strip operations. 3. Insert cable into body making certain that the cable jacket is butted against internal body shoulder and cable dielectric is started into cross hole. Solder center conductor to contact using 60/40 tin/lead solder as shown. Use a minimum amount of solder for a good joint. 4. Solder body to cable using 60/40 tin/lead solder as shown. Use a minimum of heat to minimize cable dielectric growth. Any growth of cable dielectric shall be flush with contact. 5. Press end cap into body access port using .187 (4.75) dia. flat punch. Cable Group Part No. “A” “B” RG-405/U (.086 Semi-Rigid) 142-0693-101/106 .145 (3.68) .075 (1.90) RG-402/U (.141 Semi-Rigid) 142-0694-101/106 .170 (4.32) .105 (2.67) 233 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0693-106 价格&库存
很抱歉,暂时无法提供与“142-0693-106”相匹配的价格&库存,您可以联系我们找货
