SMA Straight Solder Type for Semi-Rigid Cables
1. Identify the connector (plug or jack) and tools.
2. Strip the cable jacket and dielectric to dimension
shown. Do not nick the center conductor.
3. Bevel the entire diameter on the end of the cable
center conductor until the point resembles the
appropriate dimensional profile. This operation can be
accomplished effectively by using the recommended
center conductor pointing tool as described in step 4.
4. Insert the stripped cable into the bushing of the
appropriate pointing tool until the center conductor
just touches the blade. While maintaining light pressure
on the center conductor against the blade, turn the
tool in a counter-clockwise fashion as viewed from the
bushing end of the tool. Continue cutting the center
conductor point until the cable jacket bottoms out
inside the bushing.
5. Attach the appropriate soldering mating fixture to the
connector and tighten to a maximum of 8 inch pounds
of torque.
6. Clean all debris from the prepared cable and insert the
cable into the connector, making sure that the cable
jacket bottoms out against the internal shoulder of the
connector body.
7. Insert the stop screw into the mating fixture. Clamp the
cable and fixtured connector assembly securely in the
soldering vise. Solder the connector body to the cable
as shown, while insuring the cable dielectric expansion
does not move the assembly. Allow the assembly to
cool before removing the connector from the fixture.
241
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
SMA Straight Solder Type for Semi-Rigid Cables (cont’d from last page)
Cable Group
Part No.
RG-405/U (.086 Semi-Rigid)
141-0593-421
141-0693-062
RG-402/U (.141 Semi-Rigid)
141-0594-421
141-0694-062
242
+1 507.833.8822
inquiry@cinch.com
cinch.com
ccsjai 02.17
很抱歉,暂时无法提供与“141-0694-062”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+66.38853250+8.60522
