SMB7H-P-C-H-RA-CA3
SMB7H-P-C-H-RA-CA3
    SAMTEC(申泰)
    SMB
SMB7H-P-C-H-RA-CA3 数据手册
REVISION K SMB7H-P-C-XX-RA-CA3 DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] GENDER TERMINATION -P: PLUG DO NOT SCALE FROM THIS PRINT -CA3: CABLE (RG179) TYPE ORIENTATION -C: CABLE -RA: RIGHT ANGLE PLATING SPECIFICATION -HN:30μ" GOLD CENTER CONTACT, 3μ" GOLD OUTER CONTACT, 100μ" NICKEL REMAINING PARTS -HF: 30μ" GOLD CENTER CONTACT, 3μ" GOLD OUTER CONTACT, 3μ" GOLD REMAINING PARTS *-H: 30μ" GOLD CENTER CONTACT, 3μ" GOLD OUTER CONTACT, 3μ" GOLD REMAINING PARTS (SEE TABLE 1) 1 (*=EXISTING CUSTOMER ONLY) 3 2.70 .11 11.60 .46 REF 3.90 .15 REF 12.00 .47 REF 2 7.00 .28 REF 1.34 .05 REF 5.02 .20 REF NOTES: 1. NOTE DELETED. 2. NOTE DELETED. 3. NOTE DELETED. 4. NOTE DELETED. 5. PRODUCT TO BE BULK PACKAGED PER PACKAGING STANDARD CO-RF-WI-3040-M. 6. NOTE DELETED. 7. NOTE DELETED. 8. NOTE DELETED. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL, FERRULE, CAP: BRASS CONTACT: COPPER ALLOY DIELECTRIC: PTFE SHEET SCALE: 3:1 DESCRIPTION: TRUE 75 OHM, SMB RIGHT ANGLE PLUG, RG179 DWG. NO. SMB7H-P-C-XX-RA-CA3 BY: G. HERMAN F:\DWG\MISC\MKTG\SMB7H-P-C-XX-RA-CA3-MKT.SLDDRW 03/24/2008 SHEET 1 OF 2 REVISION K IN-PROCESS 1 STRIP CABLE AND TIN INNER CONDUCTOR RG179 CABLE 1.9 .07 4.9 .19 10.1 .40 2 IN-PROCESS 2 ADD HEAT SHRINK TUBING AND FERRULE HEAT SHRINK 20.00 .787 END OF CABLE DIELECTRIC SHOULD SEAT AGAINST CONTACT CUP 1 'D' IN-PROCESS 3 FLARE SHIELD & ADD SUB ASSEMBLY DETAIL 'D' IN-PROCESS 4 CRIMP FERRULE (USE RF CRIMP HAND TOOL#CAT-RF-FER-01, AND .128" DIE SIZE) 'B' CABLE CENTER CONDUCTOR SHOULD NOT PROTRUDE OUTSIDE CONTACT CUP AFTER FERRULE IS CRIMPED FERRULE SHOULD BE FLUSH TO SUB ASSEMBLY DETAIL 'B' IN-PROCESS 5 SOLDER SIGNAL SOCKET IN-PROCESS 6 PRESS CAP WITH CHAMFERED EDGE INWARDS 3 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR HEAT SHRINK SHOULD BE FLUSH TO SUB ASSEMBLY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING IN-PROCESS 7 ATTACH HEAT SHRINK 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY SHEET SCALE: 1.25:1 DESCRIPTION: TRUE 75 OHM, SMB RIGHT ANGLE PLUG, RG179 DWG. NO. SMB7H-P-C-XX-RA-CA3 BY: G. HERMAN F:\DWG\MISC\MKTG\SMB7H-P-C-XX-RA-CA3-MKT.SLDDRW 03/24/2008 SHEET 2 OF 2
SMB7H-P-C-H-RA-CA3 价格&库存
很抱歉,暂时无法提供与“SMB7H-P-C-H-RA-CA3”相匹配的价格&库存,您可以联系我们找货
