HDBNC-P-C-GN-ST-CA6
HDBNC-P-C-GN-ST-CA6
    SAMTEC(申泰)
    BNC
HDBNC-P-C-GN-ST-CA6 数据手册
REVISION H Pb THIS PRODUCT MANUFACTURED WITH LEAD-FREE PROCESSING DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] DO NOT SCALE FROM THIS PRINT HDBNC-P-C-XX-ST-CA6X OPTION -CA6: CCA-6/CCA-1694A (USE SOLDERED CENTER CONTCAT) -CA6B: CCA-4694R (USE SOLDERED CENTER CONTACT) -CA6C: CCA-6/CCA-1694A (USE CRIMPABLE CENTER CONTACT) GENDER -P: PLUG TYPE -C: CABLE ORIENTATION -ST: STRAIGHT 1 2 PLATING SPECIFICATION -HF: HEAVY GOLD /FLASH GOLD 30µ" Au / 50µ" Ni MIN ON PIN 3µ" Au / 50µ" Ni MIN ON OUTER CONTACT 100µ" Ni MIN ON OTHER COMPONENTS -HN: HEAVY GOLD / NICKEL 30µ" Au / 50µ" Ni MIN ON PIN 100µ" Ni MIN ON OUTER CONTACT -GF: GOLD /FLASH GOLD 10µ" Au / 50µ" Ni MIN ON PIN 3µ" Au / 50µ" Ni MIN ON OUTER CONTACT 100µ" Ni MIN ON OTHER COMPONENTS -GN: GOLD / NICKEL 10µ" Au / 50µ" Ni MIN ON PIN 100µ" Ni MIN ON OUTER CONTACT (SEE TABLE 1) 3 7.75 .305 REF 24.05 .947 REF 10.00 .394 REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] NOTES: MATERIAL: 1. REPRESENTS A CRITICAL DIMENSION. 2. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-RF-WI-3040-M. F:\DWG\MISC\MKTG\HDBNC-P-C-XX-ST-CA6X-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING COUPLING NUT, SHELL, BODY, PIN, FERRULE, C-RING, FLAT WASHER : BRASS GASKET: SILICONE SPRING: STAINLESS STEEL DIELECTRIC: PTFE SHEET SCALE: 3:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HD BNC 75 OHM, ST PLUG FOR RG6 CABLE DWG. NO. HDBNC-P-C-XX-ST-CA6X BY: ALVIN W 02/16/2011 SHEET 1 OF 2 REVISION H 11.0 .43 4.2 .17 CCA-6/CCA-1694A/CCA-4694R 2.7 .11 IN-PROCESS 1 STRIP CABLE 0.10 .004 MAX ALLOWABLE GAP 2 IN-PROCESS 2 INDUCTION SOLDER SIGNAL CONTACT OR CRIMP (CA6C OPTION) USING .042" SQUARE DIE +0.40 +.016 0.42 - 0.04 .017 - .002 (TO CENTER CONTACT) DETAIL 'A' SCALE 12 : 1 IN-PROCESS 3 ADD FERRULE 3 'A' IN-PROCESS 4 FLARE BRAIDED SHIELD AND ADD SUB ASSEMBLY CABLE FOIL WRAP TO BE INSERTED INSIDE CABLE BODY 1 -CA6/CA6C: 7.25 .285 /-CA6B: 8.26[.325](HEX CRIMP) (ACROSS 2 FACES) IN-PROCESS 5 CRIMP FERRULE (USE .278" HEX DIE) (USE .325 HEX DIE FOR CCA-4694R CABLE) 0.25 .010 MAX GAP ALLOWABLE * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\HDBNC-P-C-XX-ST-CA6X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: HD BNC 75 OHM, ST PLUG FOR RG6 CABLE DWG. NO. HDBNC-P-C-XX-ST-CA6X BY: ALVIN W 02/16/2011 SHEET 2 OF 2
HDBNC-P-C-GN-ST-CA6 价格&库存
很抱歉,暂时无法提供与“HDBNC-P-C-GN-ST-CA6”相匹配的价格&库存,您可以联系我们找货
HDBNC-P-C-GN-ST-CA6
    • 1+228.64680
    • 30+218.10600
    库存:3
