8
7
ITEM NO.
NAME
MATERIAL
1
HOUSING
PA66
UL94-V0
2
SCREW
STEEL
M8/ZN PLATED
6
5
4
3
2
NOTES
3
WIRE CONNECTOR
STEEL
M8/ZN PLATED
4
CONDUCTOR
COPPER ALLOY
TIN PLATED
1
REVISIONS
REV
ZONE
DESCRIPTION
DATE
ECN
BY
A
INITIAL RELEASE
09/24/2012
BU-J12374
TJN
F
F
PART NO.
COLOR
PANTONE #
DP150-GY
GREY
COOL GRAY2U
DP150-BU
BLUE
300U
DP150-LK
BLACK
BLACK
25.00
38.00
A
2
E
E
1
4
88.50
D
D
3
C
SECTION A-A
A
C
85.30
B
B
NOTES:
1.
RATINGS: UL 600V/230A, IEC 1000V/232A
INSULATION WITHSTAND VOLTAGE 2500VAC/1MINUTE
TEMPERATURE RANGE -40°C~105°C
2.
SEE 2A2943 FOR DIN DIMENSION DETAILS
3.
SLA3_BUSS_NAE_GENRL_REV_A
A
3D VIEW
SCALE NONE
SCREW TORQUE 10.3N-M (89.3IN-LB)
-THIS DRAWING IS AN UNCONTROLLED COPY IF
PRINTED OR SENT ELECTRONICALLY,
DO NOT SCALE DRAWING
4.
WIRE RANGE UL 4/0~2AWG, IEC 35~95 mm²
5.
ASSEMBLY MUST BE FREE OF OIL, GREASE AND OTHER FOREIGN MATERIALS.
6.
MODEL VERSION
MODEL SOURCE DATA
CONFIDENTIAL. THE INFORMATION CONTAINED IN THIS DOCUMENT
IS THE PROPERTY OF COOPER INDUSTRIES, INC. IT IS NOT FOR PUBLIC
DISCLOSURE. POSSESSION OF THE INFORMATION DOES NOT CONVEY ANY
RIGHT TO LOAN, SELL, OR DISCLOSE THE INFORMATION. UNAUTHORIZED
REPRODUCTION OR USE OF THE INFORMATION IS PROHIBITED. THIS DOCUMENT
IS TO BE RETURNED TO COOPER INDUSTRIES, INC. UPON COMPLETION OF THE
PURPOSE FOR WHICH IT WAS LOANED OR UPON REQUEST.
ASSEMBLY MUST COMPLY WITH RoHS SPECIFICATION #1P2163.
COPYRIGHT. COOPER INDUSTRIES, INC.
THIS IS AN UNPUBLISHED WORK. THE DISCLOSURE OF THIS WORK IS LIMITED
TO SELECT PERSONNEL. FURTHER DISSEMINATION OR DISCLOSURE TO THE
PUBLIC IS PROHIBITED. THIS UNPUBLISHED WORK IS PROTECTED BY FEDERAL
COPYRIGHT LAW AND ALL RIGHTS THEREUNDER ARE RESERVED BY
8
7
6
5
4
APPROVALS
GENERAL DRAWING PRACTICES IN
ACCORDANCE WITH ASME - Y14.100-2004
DIMENSIONS AND TOLERANCES IN
ACCORDANCE WITH ASME - Y14.5M-1994
TJN
= ± 0.3 mm
= ± 0.13 mm
= ± 1°
SPECIAL CHARACTERISTIC
SIGNIFICANT CHARACTERISTIC
09/26/2012
DRAWN
UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN
MILLIMETERS TOLERANCES TO BE
ONE PLACE X.X
TWO PLACE X.X X
ALL ANGLES X.X
DATE
ENGINEER
TJN
09/26/2012
MANUFACTURING ENGINEER
FEED THROUGH TERMINAL BLOCK
SEE TABLE
(0)
(0)
SIZE
FINISH
DWG NO.
A3
SEE TABLE
SCALE:
THIRD ANGLE PROJECTION
3
A
St. Louis, MO 63178 (USA)
TITLE
MATERIAL
2
REV
DP230-XX
A
1:1
SHEET
1
1 OF 1
Fr i M
a r
0 7 ,
2 0 1 2
4 : 0 X
PM
G
PK
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
DP230-GY
很抱歉,暂时无法提供与“DP230-GY”相匹配的价格&库存,您可以联系我们找货
