142-0207-101
142-0207-101
    CINCH
    SMA
142-0207-101 数据手册
SMA Clamp Type Right Angle Plugs for Flexible Cable 1. Identify connector parts. (4 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide clamp nut and clamp cone onto cable as shown. Clamp cone must be oriented as shown for each size of cable. The RG58/142 clamp cone slides over braid and against jacket. 3. Flare braid and slide cable into body making certain that the cable insulation bottoms on center contact. Stepped down diameter of stem must slide under braid and jacket. Arrange braid uniformly around crimp stem. Slide clamp nut against clamp cone and braid and tighten to 10 in.-lb. torque. 4. Solder center conductor to contact through the rear access port. Use a minimum amount of solder for a full fillet joint. .020 (0.51) diameter solder is recommended. Place expansion cap in access port and seat with .187 (4.75) diameter flat punch. Cable Group Part No. “A” “B” “C” RG-178/U, 196 142-0202-101 142-0202-106 .280 (7.11) .280 (7.11) .053 (1.35) .053 (1.35) .085 (2.16) .085 (2.16) RG-316/U, 161, 174, 188 142-0203-101 142-0203-106 .280 (7.11) .280 (7.11) .053 (1.35) .053 (1.35) .085 (2.16) .085 (2.16) RG-58/U 141, 303 142-0207-101 142-0207-106 .395 (10.03) .395 (10.03) .160 (4.06) .160 (4.06) NONE NONE RG-55/U, 142, 233, 400 142-0207-101 142-0207-106 .420 (10.67) .420 (10.67) .180 (4.57) .180 (4.57) NONE NONE 251 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0207-101 价格&库存
很抱歉,暂时无法提供与“142-0207-101”相匹配的价格&库存,您可以联系我们找货
