135-3333-001
135-3333-001
    CINCH
135-3333-001 数据手册
MMCX Straight Jack for RG-316, RG-316 DS and RG-179 Size Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable jacket to dimensions shown. Do not nick braid or center conductor during strip operations. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. Slide crimp sleeve onto cable jacket. 3. Assemble contact onto cable. Solder attachment: Solder contact to center conductor. Care should be taken that excess solder is not applied. Crimp attachment: Crimp contact to center conductor using Johnson hand tool 140-0000-952 and die set 1400000-953. Crimp location should be centered between end of contact and cross-hole. Crimp attachment to solid center conductor cables is not recommended. 4. Slide body assembly over contact and under braid, then seat firmly onto contact. The body assembly will “snap” over the contact barb. The cable may have to be held in a soft jawed clamping fixture. Slide crimp sleeve forward and crimp using recommended crimp die hex. Cable Group Part No. Crimp Hex RG-316/U, 188, 161, 174 135-3303-001 .128 (3.25) RG-316 DS, 188 DS, 187 DS 135-3304-001 .151 (3.83) RG-179/U, 187 135-3333-001 .128 (3.25) RG-316/u, 188, 174 135-9403-001 .128 (3.25) RG-316 DS, 188 DS 135-9404-001 .151 (3.83) 224 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
135-3333-001 价格&库存
很抱歉,暂时无法提供与“135-3333-001”相匹配的价格&库存,您可以联系我们找货
