HP75BNC2X
HP75BNC2X
    SWITCHCRAFT
    BNC
HP75BNC2X 数据手册
BNC CONNECTORS HP75BNC SERIES BNC CONNECTORS Switchcraft Inc. introduces a complete line of true 75 Ohm BNC cable mount connectors. This new series was developed for the broadcast industry, or wherever true 75 Ohm impedance BNC's are used. The HP75BNC Series is available in a wide range of styles, to accommodate the most popular types of coaxial cables. All are crimp terminated using standard crimping tools. Features and Benefits • True 75 Ohm impedance • Gold-plated center pins for increased life • Available for a wide range of cable types • Outstanding electrical performance • Rugged nickel-plated, machined shells Specifications Electrical Characteristic Impedance: 75 Ohms Voltage Rating: 500 Volts RMS Return Loss: Less than -25 db at 3 GHz Insulation Resistance: 5000 Megohms min Mechanical Lifecycles: 500 min Center Contact Retention: 6 lbs. min Coupling Mechanism: 100 lbs. min Force to Engage: 2.5 lbs. max Environmental Thermal Shock: -65° C to 165° C Moisture Resistance: Mil Std 202 Corrosion: Mil Std 202 Flammability: UL 94-VO Vibration: Mil Std 202 Solvent Resistance: Mil Std 202 Finish Body/Bayonet: Nickel-plated copper alloy Center Conductor: 50 mi gold-plated copper alloy Ordering Information Part Number HP75BNC1 HP75BNC2 HP75BNC6 HP75BNC7 HP75BNC9 HP75BNC10 HP75BNC12 Cable Type Belden #8241 Belden #8281B Belden #1695A Belden #1694A Belden #1505A Belden #1506A Belden #1855A 5555 North Elston Avenue, Chicago, IL 60630, Phone: 773-792-2700, Fax: 773-792-2129 PRODUCT BULLETIN 549
HP75BNC2X 价格&库存
很抱歉,暂时无法提供与“HP75BNC2X”相匹配的价格&库存,您可以联系我们找货
