142-1701-586
142-1701-586
    CINCH
    SMA
142-1701-586 数据手册
50 Ohm SMA Field Replaceable 4-Hole Flange Mount Jack Receptacle Without EMI Gasket ACCEPTS PIN SIZE FREQUENCY RANGE .020 (0.51) 0-26.5 GHz GOLD PLATED 142-1701-581 INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST NICKEL PLATED 142-1701-586 Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com SMA - 50 Ohm Connectors Field Replaceable - Application Notes INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST The field replaceable style of connector is known by many names in the industry, such as MIC launcher, hermetic seal launcher, spark plug launcher, etc. Some types, such as those known as “spark plugs”, have the hermetic seal incorporated into the connector. Thes e types require special welding to install and can not be replaced without destroying the hermeticity of the circuit housing. True fie ld replaceable connectors, such as those manufactured by Johnson Components TM, are easy to install and replace. Because the hermetic seal is not incorporated into the connector design, the connector can be removed and replaced without destroying the hermetic seal or the h ermeticity of the circuit housing. All of the above mentioned connector types perform the same basic function - creating a transition from microstrip circuitry to a coaxial transmission line. Whenever possible, the hermetic seal pin diameter should be chosen as close as possible to the microstrip t race width. For optimum electrical performance, the transition from the hermetic seal to the microstrip trace must be properly compensated. Compensation involves adjusting the microstrip trace width to minimize any impedance discontinuities found in the transition area. The plot shown below is representative of the typical return loss of an Johnson Components TM field replaceable connector. To produce the data shown below, a test fixture is created using the appropriate Johnson Components TM hermetic seal. The fixture consists of a suitably thick spacer plate with the hermetic seal mounted flush to both surfaces. Two connectors are mounted back to back around the f ixture and the VSWR of this test assembly is measured. The return loss data shown is equivalent to the square root of the measured VSWR o f the test assembly. Since the connectors tested are of identical design, it can be stated with fair accuracy that the data shown re presents the response of a single field replaceable connector and its transition to the hermetic seal. Although Johnson Components TM does not publish a VSWR specification for field replaceable connectors, typical connector VSWR can be expected to be less than 1.1 + .01f (f in GHz). A VSWR specification is not stated because an industry standard method for tes ting field replaceable connectors does not exist. The actual performance of the connector is dependent upon the application for the follo wing reasons: 1. 2. 3. The choice of hermetic seal to be used by the customer is not specified by the connector manufacturer. Hermetic seals produc ed by different manufacturers will not have the same electrical characteristics. For optimum electrical performance, Johnson Comp onentsTM recommends the use of our standard 142-1000-001, 002, 003 and 004 hermetic seals for pin diameters of .012 (0.30), .015 (0.38), .018 (0.46) and .020 (0.51). Custom hermetic seal configurations can be quoted. It is recommended that the hermetic seal be mounted flush with the circuit housing. Tolerance variations between the hermeti c seal and machined housing do not always guarantee an optimum transition to the connector. Some manufacturers recommend an additional counterbore in the circuit housing to accommodate a solder washer during installation of the seal. Johnson Compo nentsTM does not recommend this type of installation because if the counterbore is not completely filled with solder, electrical discontinuities may be created. The transition between the hermetic seal pin and the microstrip trace will affect electrical performance, as stated above. S everal different methods of hermetic seal mounting and seal pin to microstrip trace attachment are used in the industry. Johnson Components TM can not recommend one method over the other as this is dependent upon the customer’s application. As always, quotes for non-standard field replaceable connectors and/or hermetic seals are welcome. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com SMA - 50 Ohm Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST ELECTRICAL RATINGS Impedance: 50 ohms Frequency Range: Dummy loads .......................................................................... 0-2 GHz Flexible cable connectors ................................................... 0-12.4 GHz Uncabled receptacles, RA semi-rigid and adapters ........... 0-18.0 GHz Straight semi-rigid cable connectors and field replaceable connectors ............................................... 0-26.5 GHz VSWR: (f = GHz) Straight Right Angle Cabled Connectors Cabled Connectors RG-178 cable .............................. 1.20 + .025f 1.20 + .03f RG-316, LMR-100 cable .............. 1.15 + .02f 1.15 + .03f RG-58, LMR-195 cable ................ 1.15 + .01f 1.15 + .02f RG-142 cable ............................... 1.15 + .01f 1.15 + .02f LMR-200, LMR-240 cable ............ 1.10 + .03f 1.10 + .06f .086 semi-rigid ............................ 1.07 + .008f 1.18 + .015f .141 semi-rigid (w/contact) .......... 1.05 + .008f 1.15 + .015f .141 semi-rigid (w/o contact) ...... 1.035 + .005f Jack-bulkhead jack adapter and plug-plug adapter ................. 1.05 + .01f Jack-jack adapter and plug-jack adapter ............................... 1.05 + .005f Uncabled receptacles, dummy loads .................................................. N/A Field replaceable (see page 59) ......................................................... N/A Working Voltage: (Vrms maximum) Connectors for Cable Type Sea Level 70K Feet RG-178 ...................................................................... 170 45 RG-316; LMR-100, 195, 200 ..................................... 250 65 RG-58, RG-142, LMR-240, .086 semi-rigid, uncabled receptacles, .141 semi-rigid w/o contact ... 335 85 .141 semi-rigid with contact and adapters ................. 500 125 Dummy loads ................................................................................. N/A Dielectric Withstanding Voltage: (VRMS minimum at sea level) Connectors for RG-178 ................................................................... 500 Connectors for RG-316; LMR-100, 195, 200 .................................. 750 Connectors for RG-58, RG-142, LMR-240, .086 semi-rigid, field replaceable, uncabled receptacles ...................................... 1000 Connectors for .141 semi-rigid with contact and adapters ............ 1500 Connectors for .141 semi-rigid w/o contact, dummy loads .............. N/A Corona Level: (Volts minimum at 70,000 feet) Connectors for RG-178 ................................................................... 125 Connectors for RG-316; LMR-100, 195, 200 .................................. 190 Connectors for RG-58, RG-142, LMR-240, 086 semi-rigid, uncabled receptacles, .141 semi-rigid w/o contact .......................... 250 Connectors for .141 semi-rigid with contact and adapters .............. 375 Dummy loads ...................................................................................... N/A Insertion Loss: (dB maximum) Straight flexible cable connectors and adapters ...................... 0.06 f (GHz), tested at 6 GHz Right angle flexible cable connectors ......................... 0.15 f (GHz), tested at 6 GHz Straight semi-rigid cable connectors with contact ..... 0.03 f (GHz), tested at 10 GHz Right angle semi-rigid cable connectors ......................... 0.05 f (GHz), tested at 10 GHz Straight semi-rigid cable connectors w/o contact ...... 0.03 f (GHz), tested at 16 GHz Straight low loss flexible cable connectors ................ 0.06 f (GHz), tested at 1 GHz Right Angle low loss flexible cable connectors ................ 0.15 f (GHz), tested at 1 GHz Uncabled receptacles, field replaceable, dummy loads ..................... N/A Insulation Resistance: 5000 megohms minimum Contact Resistance: (milliohms maximum) Initial After Environmental Center contact (straight cabled connectors and uncabled receptacles) ........................... 3.0* 4.0* Center contact (right angle cabled connectors and adapters) .............................. 4.0 6.0 Field replaceable connectors ........................ 6.0 8.0 Outer contact (all connectors) ........................... 2.0 N/A Braid to body (gold plated connectors) ............. 0.5 N/A Braid to body (nickel plated connectors) ........... 5.0 N/A *N/A where the cable center conductor is used as a contact RF Leakage: (dB minimum, tested at 2.5 GHz) Flexible cable connectors, adapters and .141 semi-rigid connectors w/o contact ............................................................. -60 dB Field replaceable w/o EMI gasket .............................................. -70 dB .086 semi-rigid connectors and .141 semi-rigid connectors with contact, and field replaceable with EMI Gasket ................ -90 dB Two-way adapters ...................................................................... -90 dB Uncabled receptacles, dummy loads .............................................. N/A RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz) Connectors for RG-178 ................................................................... 335 Connectors for RG-316; LMR-100, 195, 200 .................................. 500 Connectors for RG-58, RG-142, LMR-240, .086 semi-rigid, .141 semi-rigid cable w/o contact, uncabled receptacles .............. 670 Connectors for .141 semi-rigid with contact and adapters ............ 1000 Power Rating (Dummy Load): 0.5 watt @ + 25°C, derated to 0.25 watt @ +125°C MECHANICAL RATINGS Engagement Design: MIL-C-39012, Series SMA Engagement/Disengagement Force: 2 inch-pounds maximum Mating Torque: 7 to 10 inch-pounds Bulkhead Mounting Nut Torque: 15 inch-pounds Coupling Proof Torque: 15 inch-pounds minimum Coupling Nut Retention: 60 pounds minimum Contact Retention: 6 lbs. minimum axial force (captivated contacts) 4 inch-ounce minimum torque (uncabled receptacles) ENVIRONMENTAL RATINGS Temperature Range: - 65°C to + 165°C Thermal Shock: MIL-STD-202, Method 107, Condition B Corrosion: MIL-STD-202, Method 101, Condition B Cable Retention: Axial Force*(lbs) Torque (in-oz) Connectors for RG-178 ............................ 10 N/A Connectors for RG-316, LMR-100 ........... 20 N/A Connectors for LMR-195, 200 .................. 30 N/A Connectors for RG-58, LMR-240 ............. 40 N/A Connectors for RG-142 ............................ 45 N/A Connectors for .086 semi-rigid ................. 30 16 Connectors for .141 semi-rigid ................. 60 55 *Or cable breaking strength whichever is less. Durability: 500 cycles minimum 100 cycles minimum for .141 semi-rigid connectors w/o contact (Meets or exceed the applicable paragraph of MIL-C-39012) Shock: MIL-STD-202, Method 213, Condition I Vibration: MIL-STD-202, Method 204, Condition D Moisture Resistance: MIL-STD-202, Method 106 †Avoid user injury due to misapplication. See safety advisory definitions inside front cover. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com SMA - 50 Ohm Connectors Specifications INCHES (MILLIMETERS) CUSTOMER DRAWINGS AVAILABLE UPON REQUEST MATERIAL SPECIFICATIONS Bodies: Brass per QQ-B-626, gold plated* per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Contacts: Male - brass per QQ-B-626, gold plated per MIL-G-45204 .00003" min. Female - beryllium copper per QQ-C-530, gold plated per MIL-G-45204 .00003" min. Nut Retention Spring: Beryllium copper per QQ-C-533. Unplated Insulators: PTFE fluorocarbon per ASTM D 1710 and ASTM D 1457 or Tefzel per ASTM D 3159 or PFA 340 per ASTM Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Crimp Sleeves: Copper per WW-T-799 or brass per QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Mounting Hardware: Brass per QQ-B-626 or QQ-B-613, gold plated per MIL-G-45204 .00001" min. or nickel plated per QQ-N-290 Seal Rings: Silicone rubber per ZZ-R-765 EMI Gaskets: Conductive silicone rubber per MIL-G-83528, Type M * All gold plated parts include a .00005" min. nickel underplate barrier layer. Mating Engagement for SMA Series per MIL-C-39012 JACK PLUG PLUG JACK NOTES 1. ID OF CONTACT TO MEET VSWR, CONTACT RESISTANCE AND INSERTION WITHDRAWAL FORCES WHEN MATED WITH DIA .0355-.0370 MALE PIN. Cinch Connectivity Solutions 299 Johnson Avenue SW, Waseca, MN 56093 USA • 800.247.8256 • +1 507 833 8822 • cinchconnectivity.com
142-1701-586 价格&库存
很抱歉,暂时无法提供与“142-1701-586”相匹配的价格&库存,您可以联系我们找货
  • 250+101.17467250+13.10566
