142-0302-436
142-0302-436
    CINCH
    CONNSMAJACKSTR50OHMCRIMP
142-0302-436 数据手册
SMA 3-Piece Plug, Jack and Bulkhead Jack for RG-178 Flexible Cable 1. Identify piece parts. (4 piece parts plus nut and washer for bulkhead.) 2. Strip cable jacket and braid to dimensions shown. Do not nick braid during strip operations. 3. Slide crimp insert over braid and against jacket. Fold braid around crimp insert as shown. Strip dielectric to dimension shown. If cable is being manually stripped the rear insulator can be assembled and used as a guide. Do not nick center conductor during strip operation. Tin center conductor if contact is to be solder attached. Do not tin center conductor if contact is to be crimp attached. 4. Assemble rear insulator over cable dielectric and contact over center conductor as shown. Solder attachment: Solder contact to center conductor using 60/40 tin/lead solder. Care should be taken that excess solder is not applied. Crimp attachment: Crimp contact to center conductor using production tooling or hand tool 144-0000-910, setting #2 with positioner 141-0000-907. Crimp location should be centered between end of contact and x-hole. Crimp attachment to solid center conductor cables is not recommended. 5. Slide body assembly over contact, rear insulator and crimp insert. Crimp body using recommended crimp tool. Maintain forward pressure on cable while crimping. Body crimp die hex: .105 (2.67) hex. Cable Group Part No. Crimp Hex RG-178/U, 196 142-0402-011 142-0402-016 142-0302-011 142-0302-016 142-0302-431 142-0302-436 .105 (2.67) .105 (2.67) .105 (2.67) .105 (2.67) .105 (2.67) .105 (2.67) 237 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-0302-436 价格&库存
很抱歉,暂时无法提供与“142-0302-436”相匹配的价格&库存,您可以联系我们找货
  • 250+105.26841250+13.65849
