PRODUCT DATA DRAWING
ROHS COMPLIANT
.182 4.62
SMP SMOOTH BORE
INTERFACE PER
MIL-STD-348
5X
.090 2.29
APPROVED
STW
2X
.100 2.54
4X
.020±.003 0.51±0.08
MATERIAL:
INSULATOR:
DATE
11/19
+.000
3.05
- .003
- 0.08
.027±.001 0.69±0.03
NOTES:
1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE
CONTACT US AT applications@svmicro.com
PC LEGS BODY &
CONTACT:
DCN 49469
+.000
3.01
- .003
- 0.08
.218 5.54
INTERFACE BODY:
REVISION HISTORY
DESCRIPTION
REV
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
4X
.038±.001 0.97±0.03
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
2X .050 1.27
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
FINISH:
INTERFACE BODY:
PC LEGS BODY &
CONTACT:
PASSIVATED PER AMS-2700
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
DWV:
OPERATING TEMP.:
.0325±.0015 0.83±0.04
RECOMMENDED MOUNTING HOLE PATTERN
MATERIAL:
FINISH:
50 OHMS
DC TO 40.0 GHz
325 VRMS
-55 C TO +125 C
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
.030
.010
.005
ANGULAR: X
X X'
1 0'
15'
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
PJS 12/14/10
CHECKED:
APPROVED:
STW 11/20/19
STW 11/20/19
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMP MALE SB
PC MOUNT
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 15:1
SF1211-6045
SHEET 1 OF 1
很抱歉,暂时无法提供与“SF1211-6045”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+344.578971+44.60216
- 10+292.8568710+37.90727
- 25+274.5289725+35.53492
- 50+261.4312950+33.83956
- 100+248.96632100+32.22610
- 250+233.39843250+30.21100
