142-4435-006
142-4435-006
    CINCH
    RP-SMA
142-4435-006 数据手册
Straight SMA Low Loss Diameter .195, .200 and .240 Straight Type Plugs 1. Identify connector parts. (3 piece parts – except bulkhead) 2. Strip cable to dimensions shown. Do not nick braid, foil or center conductor. Cut foil flush with dielectric, do not remove foil. Make sure that dielectric is clean and free from all particles. Tin center conductor, keeping solder amount to a minimum. Slide crimp sleeve onto jacket of cable. 3. Assemble contact onto cable as shown. Position contact such that a gap of no more than .020 (0.51) is kept between dielectric and contact. Solder contact to center conductor through solder hole using .020 (0.51) Diameter solder. Use a minimum amount of solder for a good joint. Do not allow contact to move into dielectric during soldering process. 4. Flare braid and slide body assembly over contact, foil and dielectric, then under braid. Seat body assembly firmly onto contact. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using Johnson hand crimp tool 141-0000-913 and recommended crimp die hex. Cable Group Part No. Crimp Hex LMR-195 142-0307-411 142-0307-416 .213 (5.41).213 (5.41) LMR-240 142-0335-401 142-0335-406 .255 (6.48).255 (6.48) LMR-200 142-0339-401 142-0339-406 .213 (5.41).213 (5.41) LMR-195 142-0407-011 142-0407-016 .213 (5.41).213 (5.41) LMR-240 142-0435-001 142-0435-006 .255 (6.48).255 (6.48) LMR-200 142-0439-001 142-0439-006 .213 (5.41).213 (5.41) LMR-240 142-4435-001 142-4435-006 .255 (6.48).255 (6.48) LMR-200 142-4439-001 142-4439-006 .213 (5.41).213 (5.41) LMR-195 142-4407-001 142-4407-006 .213 (5.41).213 (5.41) LMR-240 142-5435-001 142-5435-006 .255 (6.48).255 (6.48) LMR-200 142-5439-001 142-5439-006 .213 (5.41).213 (5.41) LMR-195 142-5407-001 142-5407-006 .213 (5.41).213 (5.41) 240 Cinch Connectivity Solutions Waseca 299 Johnson Avenue SW, Suite 100 Waseca, MN 56093 USA +1 507.833.8822 inquiry@cinch.com cinch.com © 2017 Cinch Connectors, Inc. ccsjai 02.17
142-4435-006 价格&库存
很抱歉,暂时无法提供与“142-4435-006”相匹配的价格&库存,您可以联系我们找货
