2985-6004
2985-6004
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMAJACKSTR50OHMPCB
2985-6004 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION DATE APPROVED A DCN 33567 09/05 VMJ B DCN 49750 04/20 STW REV MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B .530 13.46 FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 0.76; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN .250 6.35 SQ. EPOXY CAPTIVATED PERFORMANCE: IMPEDANCE: FREQ. RANGE: DWV: 50 OHMS DC TO 18.0 GHz 1000 VRMS 2X .200 5.08 .050 1.27 4X .040 1.02 SQ. 1/4-36 UNS-2A .155±.010 3.92±0.25 MATERIAL: FINISH: NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BRT 08/31/05 CHECKED: APPROVED: DGG 02/08/78 DGG 02/08/78 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMA JACK PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 2985-6004 SHEET 1 OF 1
2985-6004 价格&库存
很抱歉,暂时无法提供与“2985-6004”相匹配的价格&库存,您可以联系我们找货
  • 1+742.727301+96.13831
  • 10+631.2979110+81.71494
  • 25+591.7997525+76.60231
  • 50+563.5814950+72.94975
  • 100+536.71935100+69.47273
库存:115
2985-6004
    库存:100
