MMCX7-J-P-GF-RA-TH1
MMCX7-J-P-GF-RA-TH1
    SAMTEC(申泰)
    插件
    MMCX7-J-P-GF-RA-TH1
MMCX7-J-P-GF-RA-TH1 数据手册
REVISION C Pb THIS PRODUCT MANUFACTURED WITH LEAD-FREE PROCESSING DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] MMCX7-J-P-XX-RA-THX GENDER -J: JACK DO NOT SCALE FROM THIS PRINT TYPE -P: PCB LEAD STYLE -1: .093 BOARD -2: .062 BOARD -3: .039 BOARD (SEE TABLE 3) TERMINATION -TH: THROUGH HOLE ORIENTATION -RA: RIGHT ANGLE C +0.09 1.51 - 0.11 PLATING SPECIFICATION -HF: 30µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT -GF: 10µ" GOLD CENTER CONTACT, 3µ" GOLD OUTER CONTACT, (SEE TABLE 1) +.004 .059 - .004 (TO CENTER CONTACT) "A" 2.70 .106 REF (REF PLANE) 'B' 5 2.30 .091 REF 4.61 .181 REF (TYP) 2.86 .113 REF (TYP) "B" REF (TYP) 'C' 1 2 0.50 .020 REF (TYP) "A" REF (TYP) "A" 3.50 .138 REF 3 FIG 1 MMCX7-J-P-XX-RA-TH1-ASM SHOWN -TH2 & -TH3 IS SIMILAR 0.50 .020 REF (TYP) 0.30 .012 REF 0.35 A B 4 RECOMMENDED PCB LAYOUT C 0.84±0.05 .033±.002 (PTH) (4 PLCS) SECTION "A"-"A" 3.50 .138 REF 0.24 .009 REF "C" REF (TYP) 2.90 .114 REF (TYP) (ON FLATS) 0.50±0.05 .020±.002 (PTH) 4.76 .187 REF 3.00 .118 (TYP) POSITION INSULATOR DETAIL 'B' SCALE 16 : 1 NOTES: FLUSH TO BODY +/-0.08 DETAIL 'C' SCALE 16 : 1 C 3.50 .138 REF -A- 3.50 .138 REF -B- 1. C REPRESENTS A CRITICAL DIMENSION. 2. PRODUCT TO BE PACKAGED PER PACKING STANDARD CO-RF-WI-3040-M. TRAY: TY-SMA001-1 COVER: TY-SMA001-2 100 PARTS PER TRAY (1 PARTS PER POCKET) F:\DWG\MISC\MKTG\MMCX7-J-P-XX-RA-THX-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS [INCHES]. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 5 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: 3.00 .118 (TYP) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHELL: BRASS SOCKET: BeCu INSULATOR1 & INSULATOR2: PTFE C-RING: BeCu SHEET SCALE: 6:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MMCX RIGHT ANGLE THROUGH HOLE, JACK- 75 OHM DWG. NO. MMCX7-J-P-XX-RA-THX BY: ALVINW 10/08/2011 SHEET 1 OF 2 REVISION C CL IN PROCESS 1 INSERT SOCKET INTO SHELL IN PROCESS 2 PRESS INSULATOR 1 INTO SHELL CL IN PROCESS 3 PRESS C-RING & INSULATOR 2 INTO SHELL * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 8:1 F:\DWG\MISC\MKTG\MMCX7-J-P-XX-RA-THX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: MMCX RIGHT ANGLE THROUGH HOLE, JACK- 75 OHM DWG. NO. MMCX7-J-P-XX-RA-THX BY: ALVINW 10/08/2011 SHEET 2 OF 2
MMCX7-J-P-GF-RA-TH1 价格&库存
很抱歉,暂时无法提供与“MMCX7-J-P-GF-RA-TH1”相匹配的价格&库存,您可以联系我们找货
MMCX7-J-P-GF-RA-TH1
  • 2+48.474212+6.28318
库存:300
MMCX7-J-P-GF-RA-TH1
  • 1+97.726171+12.66718
  • 10+88.1468310+11.42551
  • 25+78.4513125+10.16879
  • 50+48.3042050+6.26115
  • 100+43.16089100+5.59448
  • 500+41.52872500+5.38292
  • 1000+38.097191000+4.93812
  • 2000+35.915652000+4.65536
库存:300
MMCX7-J-P-GF-RA-TH1
  • 1+99.430701+12.88811
库存:100
MMCX7-J-P-GF-RA-TH1
  • 10+114.6639110+14.86263
  • 25+70.4279725+9.12881
库存:35
MMCX7-J-P-GF-RA-TH1
  • 1+81.531521+10.56804
  • 10+73.5670310+9.53569
  • 25+65.4750625+8.48682
  • 50+53.4784550+6.93183
  • 100+47.78425100+6.19375
  • 500+45.97721500+5.95953
  • 1000+43.698621000+5.66418
库存:725
MMCX7-J-P-GF-RA-TH1
    • 1+99.09000
    • 10+94.68360
    • 30+87.05880
    库存:10
