141-0701-201
141-0701-201
    CINCH
    插件
    SMA
141-0701-201 数据手册
Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors Product Catalog Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors Johnson® Stainless Steel SMA Connectors meet or exceed the performance requirements of MIL-PRF-39012. All designs are based on 50 ohm system impedance per MIL-STD-348, and operate at frequencies up to 26.5 GHz. Applications • Antennas • Base stations • Broadcast • Cable assemblies • Cellular • Instrumentation • Microwave Radio • Radar • Radios • RF and Microwave Components • Satcom • Aircraft Features • All contacts are plated with 50 micro-inches of gold for excellent durability and high frequency performance • Stainless steel bodies are offered with passivation as a standard finish, and gold plating where soldering is required • Plug interfaces and semi-rigid bulkhead jack bodies include gaskets for environmental sealing • Cabled contacts are captivated upon assembly • Flexible cable contacts can be crimped or soldered • Semi-rigid cabled plug connectors are available in one piece versions, requiring solder attachment only between the cable jacket and connector body • The right angle PC mount features a rugged one-piece body with a one-piece swept contact Table of Contents PAGE ASSEMBLY INSTRUCTIONS . . . . . . . . . . . . . . . . . . . . . . . . .14 ASSEMBLY TOOLS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 COMPETITOR CROSS REFERENCE . . . . . . . . . . . . . . . . . . .19 ELECTRICAL SPECIFICATIONS . . . . . . . . . . . . . . . . . . . . . .3-4 ENVIRONMENTAL SPECIFICATIONS . . . . . . . . . . . . . . . . . . .5 FLEXIBLE CABLE CONNECTORS . . . . . . . . . . . . . . . . . . . . . .9 MATERIAL SPECIFICATIONS . . . . . . . . . . . . . . . . . . . . . . . . .5 MECHANICAL SPECIFICATIONS . . . . . . . . . . . . . . . . . . . . . .5 MOUNTING HOLES . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6 PANEL MOUNT JACK RECEPTACLES . . . . . . . . . . . . . .10-12 PC MOUNT JACKS RECEPTACLES . . . . . . . . . . . . . . . . . . . .10 SEMI-RIGID CABLE CONNECTORS . . . . . . . . . . . . . . . . . . . .7 2 Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors ELECTRICAL SPECIFICATIONS Impedance: 50 Ohms Frequency Range: Flexible cable connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0-12.4 GHz Uncabled receptacles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0-18.0 GHz Straight Semi-Rigid cable connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0-26.5 GHz VSWR: (f = GHz) Straight Cable Connectors RG-316, LMR-100 cable . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RG-58, LMR-195 cable. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RG-142 cable . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .086 Semi-Rigid cable (0 - 18 GHz). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .086 Semi-Rigid cable (18 - 26.5 GHz) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .141 Semi-Rigid cable (w/contact) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .141 Semi-Rigid cable (w/o contact) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.15+.02f 1.15+.01f 1.15+.01f 1.07+.008f 1.35 MAX 1.05+.008f 1.035+.005f Right Angle Cable Connectors 1.15+.03f 1.15+.02f 1.15+.02f Insertion Loss: (dB maximum) Straight flexible cable connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.06 f (GHz), tested at 6 GHz Right angle flexible cable connectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.15 f (GHz), tested at 6 GHz Straight Semi-Rigid cable connectors with contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.03 f (GHz), tested at 10 GHz Straight Semi-Rigid cable connectors w/o contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.03 f (GHz), tested at 16 GHz Uncabled receptacles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . N/A Working Voltage: (Vrms maximum) Sea Level RG-316, LMR-100, 195 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 250 RG-58, RG-142, .086 Semi-Rigid, Uncabled receptacles, .141 Semi-Rigid w/o contact. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335 .141 Semi-Rigid with contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500 70K Feet 65 85 125 Dielectric Withstanding Voltage: (Vrms minimum at sea level) Sea Level Connectors for RG-316, LMR-100, 195 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 750 Connectors for RG-58, RG-142, .086 Semi-Rigid, Uncabled receptacles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000 Connectors for .141 Semi-Rigid with contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1500 Connectors for .141 Semi-Rigid w/o contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . N/A Corona Level: (Volts minimum at 70,000 feet) 70K Feet Connectors for RG-316, LMR-100, 195 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 190 Connectors for RG-58, RG-142, .086 Semi-Rigid, Uncabled receptacles, .141 Semi-Rigid w/o contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 250 Connectors for .141 Semi-Rigid with contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 375 3 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity ELECTRICAL SPECIFICATIONS cont’d RF High Potential Withstanding Voltage: (Vrms minimum, tested at 4 and 7 MHz) Connectors for RG-316, LMR-100, 195 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500 Connectors for RG-58, RG-142, .086 Semi-Rigid, .141 Semi-Rigid cable w/o contact, Uncabled receptacles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 670 Connectors for .141 Semi-Rigid with contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000 Insulation Resistance: 5000 Megohms minimum Contact Resistance: (milliohms maximum) Initial Center contact (straight cabled connectors and Uncabled receptacles) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.0* Center contact (right angle cabled connectors) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.0 Outer Contact (all connectors) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.0 Braid to Body (gold plated bodies) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.5 *N/A where the cable center conductor is used as a contact After Environmental 4.0* 6.0 N/A N/A RF Leakage: (dB minimum, tested at 2.5 GHz) Flexible cable connectors and .141 Semi-Rigid connectors w/o contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -60 .086 Semi-Rigid connectors and .141 Semi-Rigid connectors with contact . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -90 Uncabled receptacles . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . N/A 4 Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors MECHANICAL SPECIFICATIONS Engagement Design: MIL-PRF-39012, Series SMA Durability: 500 cycles minimum 100 cycles minimum for .141 Semi-Rigid connectors w/o contact Engagement/Disengagement Force: 2 inch-pounds maximum Mating Torque: 7 to 10 inch-pounds Bulkhead Mounting Nut Torque: 15 inch-pounds recommended Coupling Proof Torque: 15 inch-pounds minimum Coupling Nut Retention: 60-pounds minimum Contact Retention: 6 lbs. minimum axial force (captivated contacts) 4 inch-ounce minimum torque (uncabled receptacles) Cable Retention: (minimum*) Axial Force (lbs) Torque (in-oz) Connectors for RG-316, LMR-100 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 N/A Connectors for RG-58 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 N/A Connectors for RG-142 Cabled . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 45 N/A Connectors for .086 Semi-Rigid . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 16 Connectors for .141 Semi-rigid . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 60 55 Connectors for LMR-195 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 N/A * Or cable breaking strength, whichever is less ENVIRONMENTAL SPECIFICATIONS (Meets or Exceeds the Applicable Paragraph of MIL-PRF-39012) Temperature Range: -65°C to +165°C Thermal Shock: MIL-STD-202, Method 107, Condition B (except +85°C high temperature) Corrosion: MIL-STD-202, Method 101, Condition B Shock: MIL-STD-202, Method 213, Condition I Vibration: MIL-STD-202, Method 204, Condition D Moisture Resistance: MIL-STD-202, Method 106 MATERIAL SPECIFICATIONS Bodies: Stainless Steel, type 303, per ASTM A 582, passivated per MIL-F-14072 (EL 300), or gold Plated per MIL-G-45204 B .00003” min. Contacts: Male - Brass per ASTM B16, Gold plated* per MIL-G-45204 (.00005” min) Female – Beryllium Copper per ASTM B196, Gold plated* per MIL-G-45204 (.00005” min) Insulators: PTFE Fluorocarbon per ASTM D1710 and ASTM D1457 Gaskets: Silicon Rubber per ZZ-R-765 Expansion Caps: Brass per QQ-B-613, gold plated per MIL-G-45204 .00001” min. or nickel plated per QQ-N-290 Crimp Sleeves: Copper per ASTM A75, gold plated per MIL-G-45204 .0001”min. or nickel per QQ-N-290 plated (.00001” min) Nut Retention Spring (Plugs): Beryllium Copper per ASTM B196, un-plated Mounting Hardware: Stainless Steel, type 303, Per ASTM A 582, passivated per MIL-F-14072 (EL 300), or gold plated* per MIL-G-45204 B .00001” min. Note: All Gold plated parts include a .00005” minimum Nickel under plated barrier layer 5 Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors MATING ENGAGEMENT FOR STAINLESS STEEL SMA SERIES PER MIL-STD-348A MOUNTING HOLES Fig 1 6 Fig 2 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors Straight Solder Type Plug - with Contact, Captive Nut Thin Wall Cable Tpe VSWR & Freq. Range Gold Plated Body “A” RG-405, .086 Semi-Rigid RG-402, .141 Semi-Rigid 1.07+.008f (0-18 GHz), 1.35 Max (18-26.5 GHz) 1.05+.008f (0-26.5 GHz) 141-0693-002 141-0694-002 .440 .405 Assembly instructions page 16 Straight Solder Type Plug - without Contact, Thread-on Nut Connector Interface for .141 Cable Cable Type VSWR & Freq. Range Gold Plated Body RG-402, .141 Semi-Rigid 1.035+.005f (0-26.5 GHz) 141-0694-012 Assembly instructions page 15 Straight Solder Type Plug with Captivated Solderless Contact, Captive Nut and Thick Wall Interface Cable Type VSWR & Freq. Range Gold Plated Body RG-405, .086 Semi-Rigid RG-402, .141 Semi-Rigid 1.07+.008f (0-18 GHz), 1.35 Max (18-26.5 GHz) 1.05+.008f (0-26.5 GHz) 141-0693-062 141-0694-062 Assembly instructions page 17 Inches (Millimeter) 7 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity Straight Solder Type Jack Cable Type VSWR & Freq. Range Gold Plated RG-405, .086 Semi-Rigid RG-402, .141 Semi-Rigid 1.07+.008f (0-18 GHz), 1.35 Max (18-26.5 GHz) 1.05+.008f (0-26.5 GHz) 141-0593-001 141-0594-001 Assembly instructions page 16 Straight Solder Type Bulkhead Jack with O-Ring Cable Type VSWR & Freq. Range Gold Plated RG-405, .086 Semi-Rigid RG-402, .141 Semi-Rigid 1.07+.008f (0-18 GHz), 1.35 Max (18-26.5 GHz) 1.05+.008f (0-26.5 GHz) 141-0593-401 141-0594-401 Assembly instructions page 16 Straight Solder Type Bulkhead Jack with Captivated Solderless Contact and O-Ring Cable type VSWR & Freq. Range Gold Plated RG-405, .086 Semi-Rigid RG-402, .141 Semi-Rigid 1.07+.008f (0-18 GHz), 1.35 Max (18-26.5 GHz) 1.05+.008f (0-26.5 GHz) 141-0593-421 141-0594-421 Assembly instructions page 17 8 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors Straight Crimp Type Plug (3-piece) - Solder or Crimp Captivated Contact Cable Type VSWR & Freq. Range Passivated RG-161/U, 174,188, 316, LMR-100, HPF-100, RF-100 RG-188 DS, RG-316 DS RG-58/U, 141, 303, LMR-195, HPF-195, RF-195 RG-55/U, 142, 223, 400 1.15+.02f (0-12.4 GHz) 1.15+.02f (0-12.4 GHz) 1.15+.01f (0-12.4 GHz) 1.15+.01f (0-12.4 GHz) 141-0403-012 141-0404-012 141-0407-012 141-0408-012 Assembly instructions page 14 Right Angle Crimp Type Plug - Captivated Contact Cable Type VSWR & Freq. Range Passivated “A” “B” “C” “D” RG-161/U, 174,188, 316 RG-188 DS, RG-316 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 1.15+.03f (0-12.4 GHz) 1.15+.03f (0-12.4 GHz) 1.15+.02f (0-12.4 GHz) 1.15+.02f (0-12.4 GHz) 141-0403-102 141-0404-112 141-0407-102 141-0408-102 .652 .652 .636 .636 .527 .527 .519 .519 .593 .593 .596 .596 .467 .467 .471 .471 Assembly instructions page 18 Straight Crimp Type Bulkhead Jack (3-piece) Solder or Crimp Captivated Contact Cable Type VSWR & Freq. Range Passivated RG-161/U, 174,188, 316 RG-188 DS, RG-316 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 1.15+.02f (0-12.4 GHz) 1.15+.02f (0-12.4 GHz) 1.15+.01f (0-12.4 GHz) 1.15+.01f (0-12.4 GHz) 141-0303-412 141-0304-412 141-0307-412 141-0308-412 Assembly instructions page 14 Inches (Millimeter) 9 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity Right Angle PC Mount Jack Receptacle Freq. Range Gold Plated 0-18 GHz 141-0701-301 Mounting hole layout Figure 2 on page 6 Straight PC Mount Jack Receptacle Freq. Range Gold Plated 0-18 GHz 141-0701-201 Mounting hole layout Figure 2 on page 6 Rear Mount Bulkhead Jack Receptacle Freq. Range Passivated 0-18 GHz 141-0701-402 Mounting hole layout Figure 1 on page 6 10 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors 2-Hole Flange Mount Jack Receptacle - Flush Dielectric Freq. Range Passivated 0-18 GHz 141-0701-602 4-Hole Flange Mount Jack Receptacle - Flush Dielectric Freq. Range Passivated 0-18 GHz 141-0701-612 Inches (Millimeter) 11 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity 2-Hole Flange Mount Jack Receptacle - Extended Dielectric VSWR & Freq. Range Passivated 1.15+.02f (0-18 GHz) 141-0701-622 4-Hole Flange Mount Jack Receptacle - Extended Dielectric VSWR & Freq. Range Passivated 1.15+.02f (0-18 GHz) 141-0701-632 12 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors ASSEMBLY TOOLS Semi-Rigid Assembly Tools Accurate assembly of the Semi-Rigid Cabled Connectors is obtained with the tools listed below. Industry standard devices are used if possible for customer convenience and tool compatibility. B. A. D. I. C. E. G. F. H. Item Part No. Description A B 140-0000-962 140-0000-964 140-0000-965 140-0000-973 140-0000-975 140-0000-976 140-0000-977 140-0000-978 140-0000-979 140-0000-980 140-0000-981 140-0000-982 Soldering Vise (does not include inserts (B) or stop screw (H) ) Semi-Rigid Cable Clamp Inserts for .086" OD Cable Semi-Rigid Cable Clamp Inserts for .141" OD Cable Soldering Mating Fixture for SMA Jack Connectors Complete Center Conductor Pointing Tool for .086" OD Cable Complete Center Conductor Pointing Tool for .141" OD Cable Bushing for .086" OD Cable Conductor Pointing Tool Bushing for .141" OD Cable Conductor Pointing Tool Blade for Center Conductor Pointing Tool Frame for Center Conductor Pointing Tool Stop Screw for Semi-Rigid Cable Soldering Vise Soldering Mating Fixture for SMA Plug Connectors C D E F G H I Inches (Millimeter) 13 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity ASSEMBLY INSTRUCTIONS SMA Type Straight Plugs, Straight Jacks, and Straight Bulkhead Jacks for Flexible Cable Crimp or Solder Contacts 1. Identify connector parts. (3 piece parts–except bulkhead) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. Tin center conductor if contact will be solder attached. Do not tin center conductor if contact is to be crimp attached. When stripping LMR100 low loss cable, remove foil back to where cable jacket is stripped. A wire stripper of correct size is recommended for this step. Slide heat shrink (as applicable) and crimp sleeve onto jacket of cable. 3. Assemble contact onto cable as shown. Solder Attachment: Solder contact to center conductor through solder hole using .020 (0.51) diameter solder. Use a minimum amount of solder for a good joint. Crimp Attachment: Crimp contact to center conductor using Johnson® Hand Tool 144-0000-910, setting #2, with positioner 141-0000-907. Crimp location should be centered between end of contact and X-hole. Crimp attachment to solid center conductor cables is not recommended. 4. Flare braid and slide body assembly over contact and under braid. Then seat body assembly firmly onto contact. The cable may have to be held in a clamping fixture. Arrange braid uniformly around crimp stem. Slide crimp sleeve forward and crimp using recommended crimp tool. Slide heat shrink forward and shrink (as applicable). Cable Type Part No. Crimp Hex RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 141-0303-412 141-0304-412 141-0307-412 141-0308-412 141-0403-012 141-0404-012 141-0407-012 141-0408-012 .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) 14 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors SMA Solder Type Straight Plugs for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. Bevel the cable center conductor per contact detail of SMA interface on page 6. Slide coupling nut onto cable as shown. 3. Insert cable into body making sure cable jacket is flush with front of body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Trim expanded insulation flush with front of body or fixture body and cable during soldering to prevent cable insulation expansion. 4. Thread coupling nut over body. Cable Type Part No. RG-402/U (.141 Semi-Rigid) 141-0694-012 Inches (Millimeter) 15 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity SMA Solder Type Straight Jacks, Straight Plugs, and Straight Bulkhead Jacks for Semi-Rigid Cable 1. Identify connector parts. (2 piece parts) 2. Strip cable to dimensions shown. Do not nick center conductor. 3. Place center contact on center conductor making sure contact bottoms against cable insulation. Solder center conductor to center contact through solder hole. Solder must not be allowed to run on outside of contact. Use a minimum amount of solder for a good joint. .020 (0.51) diameter solder is recommended. Trim excess insulation. 4. Insert contact and cable into body assembly making sure cable is bottomed against insulator in body. Solder body to cable. Use a minimum amount of heat to minimize cable insulation movement. Cable Type Part No. “A” RG-405/U (.086 Semi-Rigid) 141-0593-001 141-0593-401 141-0693-002 141-0594-001 141-0594-401 141-0694-002 .070 (1.78) .070 (1.78) .070 (1.78) .085 (2.16) .085 (2.16) .085 (2.16) RG-402/U (.141 Semi-Rigid) 16 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors SMA Straight Solder Type for Semi-Rigid Cable 1. Identify the connector (plug or jack) and tools 2. Strip the cable jacket and dielectric to dimension shown. Do not nick the center conductor. 3. Bevel the entire diameter on the end of the cable center conductor until the point resembles the appropriate dimensional profile. This operation can be accomplished effectively by using the recommended center conductor pointing tool as described in step 4. 4. Insert the stripped cable into the bushing of the appropriate pointing tool until the center conductor just touches the blade. While maintaining light pressure on the center conductor against the blade, turn the tool in a counter-clockwise fashion as viewed from the bushing end of the tool. Continue cutting the center conductor point until the cable jacket bottoms out inside the bushing. 5. Attach the appropriate soldering mating fixture to the connector and tighten to a maximum of 8 inch pounds of torque. 6. Clean all debris from the prepared cable and insert the cable into the connector, making sure that the cable jacket bottoms out against the internal shoulder of the connector body. 7. Insert the stop screw into the mating fixture. Clamp the cable and fixtured connector assembly securely in the soldering vise. Solder the connector body to the cable as shown, while insuring the cable dielectric expansion does not move the assembly. Allow the assembly to cool before removing the connector from the fixture Cable Type Part No. RG-405/U (.086 Semi-Rigid) 141-0593-421 141-0693-062 141-0594-421 141-0694-062 RG-402/U (.141 Semi-Rigid) Inches (Millimeter) 17 Stainless Steel SMA Connectors Connectivity....for Business-Critical Continuity SMA Crimp Type Right Angle Plugs for Flexible Cable 1. Identify connector parts. (3 piece parts) 2. Strip cable to dimensions shown. Do not nick braid or center conductor. When stripping LMR-100 low loss cable, remove foil back to where cable jacket is stripped. A wire stripper of correct size is recommended for this step. Twist stranded center conductor into tight bundle and tin (optional). Slide crimp sleeve onto cable as shown. 3. Flare braid and slide cable into body making certain that the cable insulation bottoms on center contact. Solder center conductor to contact through the rear access port. Use a minimum amount of solder for a full fillet joint. .020 (0.51) diameter solder is recommended. 4. Arrange braid uniformly around crimp stem. Slide crimp sleeve over braid and crimp securely using recommended crimp tool. Place expansion cap in access port and seat with .187 (4.75) diameter flat punch. Shrink heat shrink tubing over crimp sleeve if applicable. Cable Type Part No. Crimp Hex RG-316/U, 161, 174, 188; LMR-100 RG-316 DS, 188 DS RG-58/U, 141, 303 RG-55/U, 142, 223, 400 141-0403-102 141-0404-112 141-0407-102 141-0408-102 .128 (3.25) .151 (3.83) .213 (5.41) .213 (5.41) 18 Inches (Millimeter) Connectivity....for Business-Critical Continuity Stainless Steel SMA Connectors COMPETITOR CROSS REFERENCE JOHNSON 141-0403-012 141-0404-012 141-0407-012 141-0408-012 141-0403-102 141-0404-102 141-0407-102 141-0408-102 141-0693-002 141-0694-002 141-0694-012 141-0693-062 141-0694-062 141-0303-412 141-0304-412 141-0307-412 141-0308-412 141-0593-001 141-0594-001 141-0593-401 141-0594-401 141-0593-421 141-0594-421 141-0701-201 141-0701-301 141-0701-402 141-0701-602 141-0701-612 141-0701-622 141-0701-602 Inches (Millimeter) HUBER SUHNER 11SMA-50-2-55C 11SMA-50-2-56C 11SMA-50-3-55C 11SMA-50-3-56C 16SMA-50-2-55C 16SMA-50-2-56C 16SMA-50-3-55C 16SMA-50-3-56C 11SMA-50-2-65 11SMA-50-3-65 11SMA-50-3-64 11SMA-50-2-65 11SMA-50-3-65 AMP/TYCO 225532-4 225532-1 225532-3 225609-4 225609-1 225609-3 225608-4 1-225608-1 225608-3 24SMA-50-2-41 24SMA-50-3-41 24SMA-50-2-41 24SMA-50-3-41 82SMA-50-0-1 85SMA-50-0-1 22SMA-50-0-54 23SMA-50-0-61 23SMA-50-0-51 23SMA-50-0-63 23SMA-50-0-53 221789-1 221790-1 228496-1 221641-1 221640-1 RADIAL R125072001 R125072081 R125075001 R125076001 R125172001 R125174011 R125175001 R125176001 R125052002 AMPHENOL 901-9511-3SFC 901-9511-12SFC 901-9511-2SF 901-9511-1SF 901-9531-3SF 901-9531-12SF 901-9531-2SF 901-9531-1 901-9201-2A R125054002 R125052002 R125057002 R125312121 R125313121 R125314121 R125315121 R125222000 R125225000 R125326000 R125325000 R125326000 R125325000 R125426000 R125680000 R125553001 R125454001 R125403001 R125464274 R125415275 901-9201-1A 901-9723 901-9808 901-9610-3SF 901-9610-12SF 901-9610-2SF 901-9610-1SF 901-9202-2A 901-9202-1A 901-144 901-143 901-9211-SF 901-9215-SF 901-9000-CCSF 901-9204-CCSF AEP 9101-9573-03 9101-9573-19 9101-9573-06 9101-9573-01 9043-9523-03 9043-9523-19 9043-9523-06 9043-9523-01 9401-1083-010 9401-1083-109 9301-1063-009 9401-1583-010 9401-1583-109 9130-9573-03 9130-9573-19 9130-9573-06 9130-9573-01 9402-1533-010 9402-1583-009 9453-1083-010 9453-1083-009 9453-1583-010 9453-1083-009 9650-1113-000 9647-1513-000 9412-9113-000 9408-9113-000 9404-9113-000 9008-9113-000 9004-9113-000 19 Emerson Network Power Connectivity Solutions About Emerson Network Power Connectivity Solutions Johnson 299 Johnson Avenue Waseca, MN 56093 Emerson Network Power Connectivity Solutions, an Emerson business, serves the needs of USA wireless communications, telephony and data networks, CATV, security systems, health care Tel: 800.247.8256 and industrial facilities with a full spectrum of Fax: 507.833.6287 broadband copper and fiber optic connectivity products. For more information, visit www.EmersonNetworkPower.com/Connectivity www.EmersonNetworkPower.com/Connectivity. About Emerson Emerson (NYSE: EMR), based in St. Louis, is a global leader in bringing technology and engineering together to provide innovative solutions to customers through its network power, process management, industrial automation, climate technologies, and appliance and tools businesses. Sales in fiscal 2005 were $17.3 billion. For more information, visit www.gotoemerson.com. Emerson Network Power. The global leader in enabling business-critical continuity. AC Power Systems Connectivity DC Power Systems Embedded Power Inbound Power Integrated Cabinet Solutions www.EmersonNetworkPower. com Outside Plant Precision Cooling Site Monitoring and Services Emerson Network Power and the Emerson Network Power logo are trademarks and service marks of Emerson Electric Co. ©2006 Emerson Electric Co JC0606-SS
141-0701-201 价格&库存
很抱歉,暂时无法提供与“141-0701-201”相匹配的价格&库存,您可以联系我们找货
  • 250+141.14820250+18.34881
