MMCX Right Angle Plug for RG-178 and RG-316
Size Flexible Cable
1. Identify piece parts. (3 piece parts)
2. Strip cable jacket to dimensions shown. Do
not nick braid or center conductor during strip
operations. Tin center conductor. Slide crimp sleeve
onto cable jacket.
3. Flair braid and assemble crimp stem of body
subassembly under braid onto cable making certain
that the cable center conductor enters contact slot as
shown. Arrange braid uniformly around crimp stem.
Slide crimp sleeve over braid and crimp securely
using recommended crimp hex.
4. Solder center conductor to contact through rear
access port. Use a minimum amount of solder for a
full fillet joint.
5. Press end cap into body access port using
.156 (3.96) diameter flat punch or Johnson assembly
tool 141-0000-91.
Cable Group
Part No.
Sleeve Hex
“A”
“B”
“C”
RG-178, 196
135-9402-111
.105 (2.67)
.310
.100
.035
RG-316/U, 188, 187, 179
135-9403-101
.128 (3.25)
.295
.105
.075
219
Cinch Connectivity Solutions Waseca
299 Johnson Avenue SW, Suite 100
Waseca, MN 56093 USA
+1 507.833.8822
inquiry@cinch.com
cinch.com
© 2017 Cinch Connectors, Inc.
ccsjai 02.17
很抱歉,暂时无法提供与“135-9403-101”相匹配的价格&库存,您可以联系我们找货
